EJS2015 Posted September 22, 2024 Author Posted September 22, 2024 5 hours ago, Jeremy984 said: I have checked the date and time settings in the Carlin Kit settings and my truck. They are both set to automatic. So it should sync. I tried to adjust each one manually to see if one feeds another. I can’t get this message to go away. Also, the file to put on the SD card, mine starts with what looks like Chinese writing in step 1 and 2. Then repeats in English step 1 and 2. Is that right? The best I can think of is downloading and installing the latest Android version. If that doesn't work, I am sure the support team will give you some help. And yes, that reverse.ini file has both Chinese and English text in it.
sloan1918 Posted September 22, 2024 Posted September 22, 2024 On 9/20/2024 at 10:21 PM, EJS2015 said: I have never seen that before. Just to clarify, what happens if you click the Date / Time button and adjust it? If it is, maybe the Tbox has the wrong time. Do you have another vehicle that has Apple Carplay? If so, try plugging it into that one and if it loads, try setting the date and time and see if it's correct. I have. Load it the first time through CarPlay, connect to WiFi. It will update the time and date. Now you can do as you please.
Aubie_01 Posted September 23, 2024 Posted September 23, 2024 Here is a somewhat related question for anyone who can help: Can I remove the ‘Trailering’ view from the right side of the screen? I never use it. Thanks!
Sky9049 Posted September 23, 2024 Posted September 23, 2024 Can you download this file onto different brands of these devices? I just bought the autoplexion one. Think it will work?
EJS2015 Posted September 23, 2024 Author Posted September 23, 2024 20 hours ago, Aubie_01 said: Here is a somewhat related question for anyone who can help: Can I remove the ‘Trailering’ view from the right side of the screen? I never use it. Thanks! I'm pretty sure you can't. Could be wrong though. 1
EJS2015 Posted September 23, 2024 Author Posted September 23, 2024 20 minutes ago, Sky9049 said: Can you download this file onto different brands of these devices? I just bought the autoplexion one. Think it will work? Not sure. Probably not. Try contacting autoplexion and asking if there is a way to change the projection mode from Carplay to Android Auto
eppieguy Posted September 27, 2024 Posted September 27, 2024 Well after using it for awhile here are my observations. There seems to be a lag and dropping volume issue when talking on the phone, a little annoying. There also seems to be an issue when it's reading texts, it cuts off the first 1-2 seconds of the text. The screen looks awesome, love the full screen look and everything seems to work great besides the phone and text issues. I'm going to give it some more time to see which ends up being more important to me.
Duramax1500 Posted October 10, 2024 Posted October 10, 2024 On 9/20/2024 at 10:14 PM, EJS2015 said: Sorry, I have not gotten on for a few days. Let's go through it. Are you using a Mac or a PC? On a Mac, open Disk Utility, click on the SD card, Erase, format to exFat, and scheme to Master Boot Record. Download that file and place it in the Tbox. On PC, right-click on the SD card, click format, select exFat for the file system, then click start. Download and put the file in there and put it into the Tbox. If that doesn't work, try to format it as fat32 instead of exfat. I’m struggling, I cannot get this to work. Once I erase format to exfat and scheme to master boot record what is my next step? You say download that file but I don’t see a place to download.
EJS2015 Posted October 10, 2024 Author Posted October 10, 2024 (edited) 7 hours ago, Duramax1500 said: I’m struggling, I cannot get this to work. Once I erase format to exfat and scheme to master boot record what is my next step? You say download that file but I don’t see a place to download. All you have to do is click the file. Edited October 10, 2024 by EJS2015
Gigemaggies2014 Posted October 16, 2024 Posted October 16, 2024 Is anyone else running into the issue where call quality is not good? People say I sound like I’m in a tunnel. Siri also sounds bad
EJS2015 Posted October 16, 2024 Author Posted October 16, 2024 57 minutes ago, Gigemaggies2014 said: Is anyone else running into the issue where call quality is not good? People say I sound like I’m in a tunnel. Siri also sounds bad After using it for a while, I found this to be true unfortunately. So that’s one drawback about this method. Carlinkit occasionally has updates for the Tbox that fixes problems like these so hopefully they will have a fix in an update soon.
Broncos123 Posted October 20, 2024 Posted October 20, 2024 Hey, I bought the product and downloaded the file onto a SD card. It says copying and appears to take the SD card but it doesn’t switch over to Android auto. Any help is appreciated as I can’t get it to go full screen?
eppieguy Posted November 5, 2024 Posted November 5, 2024 Ok, an update as to my feelings on this Mod, Screen looks awesome, I wish Car Play would be full screen! Everything works as it should I didn't play with other options the module had but there are a ton of things to see it seems, not sure what they are though. I've decided not to continue using it, why you ask..... It has a lag when reading texts in which I do a lot when driving, Speak to text has a lag as well Clarity when talking on the phone, it's not bad, but Apple Car Play is clearer in my opinion Doesn't automatically connect when you start the truck, you always have to hit the Android Icon on the screen. None of the things are real deal breakers and the maps and music screens look fantastic, it's just not for me I guess. Just my .02
Todd Sickler Posted December 30, 2024 Posted December 30, 2024 So I was gifted an Android Ai Box Ultra for Christmas and I cannot for the life of me get the full screen. Any help would be much appreciated. It’s an Android box that allows CarPlay and Android Auto, but I can’t get the Android Auto to work with my IPhone obviously, only the CarPlay. Here is the link to the box. https://a.co/d/7gbIiyA I’ve attached a picture too.
EJS2015 Posted December 30, 2024 Author Posted December 30, 2024 I’ve contacted AuroraLink (the seller of your Android Ai box to find out any info on wether it is possible to change the projection method to use Android Auto instead of CarPlay (allows the use of full screen). They should get back to me in 48 hours, maybe a little more because of the holidays. When I find out more, I will let you know.
