Has anyone replaced the factory intake setup with an Airraid Junior kit? It's just the middle intake tube, re-uses the factory intake box. I had one on my 2012, with a dry drop in filter. Made more... noise. Maybe a little quicker throttle response. I searched here, but didn't find anything. My 2024 Sierra has the 6.2. I wouldn't be expecting more than a 15-18 hp gain...
J/K...
I originally installed just a AFE dry flow drop in filter on my truck. Couple years ago I put in the K&N kit that's similar to the Airaid Junior kit. It just replaced the factory intake tube and silencer. I didn't notice any more noise or power. I kept the AFE filter instead of putting the K&N from the kit in.
Is the AFE a dry filter, or does it require oiling? I had a K&N years ago on another truck, and it got old keeping it clean and oiled..
AFE is dry filter, which is why I went with it to start with and kept it instead of the oiled K&N. I have oiled filters on other vehicles but it's because they were put on before dryflows were a thing.
4 hours ago, CDN McIntomney said:
I had great torque and power gain from S&B Cold Air intake system it was a way bigger filter than a K&N
Yeah sure you did you must sell them. Alot of people fall victim to these. They make more noise thinking you have more power.
Oh, but they do. There’s studies to back it up. My trailblazer ss had a filter much like those cold air set ups from the factory. The last TV show that did a test on cold air intakes I saw was motor week. They even claimed fuel mileage gain. They have a garage segment that was very informative. Sadly the long time host of the segment recently passed. I have been a big user of those products. Basically anything that adds performance like tuning and exhaust. Sure sound does add to the experience. The gains are real.
The gains you say is nothing your going to feal they can claim all they want even if it's .3 mpg or 2 hp increase but your not going to feal its not like the poster said of great power and torque. Also if you do multiple dyno pulls on one motor the numbers won't be the same everytime.
I use to watch motorweek but they started catering to foreign vehicles a long time ago and always found faults in America vehicles.
Edited by Silverado4x4
And electric vehicles
at 106km brought my truck to 10.3/100km and increased my fuel mileage. I was getting 500km ish per tank, brought it up over 600km gas light and  well 660 to fully empty per tank, and my truck has 34.5x12.5x20s. than after I put a pulsar LT in and was getting 9.3/100km at 106km, and around 700km gas light and 760 ish fully empty a tank I drive the same 1200km every two weeks to and from work monitored my truck alot. So to say the S&B did nothing besides make noise I find not true.
That's not running in SPORT or Off Road Mode
Running Level 1 on Pulsar LT
2021 5.3 RST
87L Tank
As for a dealer of air intakes nope. Im a Heavy Duty Equipment Technician for Toromont CAT up in the Lower Artic Circle
Edited by CDN McIntomney
    • One of the few things I enjoyed about my time in the midwest was taking off on weekend drives. Unlike home, where we are boxed in by mountains and water, those rules don't apply to the inland plains. Roads connect and sprawl everywhere. While Minnesota is flat, it's not completely featureless and there are fast moving rural roads with curves and slight elevation changes. I used to relish heading out in a particular direction with no set destination, no curfew, and weaving through little townships, wherever the roads would take me. Along farms, lakes, or through the deciduous trees... It was beautiful in its own way, and the seasons were so distinct there. Fall drives yielded amazing shows of color and contrast. Summer drives rewarded with the and amber evening glow of the prairie (and lots of juicy bugs).    I do a lot of that here in my home state too. But it's much less mysterious/intriguing. I've traveled most roads in the region, and every road that's fun to drive within a good radius of my house. But every drive, even on the same old roads, is still enjoyable. I know where I can lean hard into the throttle or really throw the car into a curve. There are exercise loops for when I just need to keep certain cars limber, and much longer routes to settle in and enjoy a drive and put some miles on. All the mountains and water make for some really awesome roads for spirited driving. But not all my driving is spirited, for example, that's not really enjoyable in my pickup or this Blazer (that's still here...).   Sometimes a good drive is followed by a ritualistic wash before tucking the car away...
    • 'GMAuthority' is reporting the 2027 HD's will have the L8S 6.6L gasoline V-8.  There was some talk here about the L8S awhile back.  Not sure what changes it will have now as it seems the 2027 emissions regulations have changed from what was originally proposed.  The big question will be is L8S just a stopgap for the last 2 years of the current T1 HD platform or will it carry forward to the next generation 2029 T1-2 HD's?    I assume the L8S will still be a Gen. V engine.
    • New engines will still be using DEF. You just won't have the limp modes occurring when you run out of DEF now.
    • I am not a NOCO fan for a charger I would leave on a battery 24/7. The reason is, it doesn't really float. It waits until the battery drops to a certain voltage and then charges it back up to 14V. It's better than no charger I guess.
    • I would never do anything but lithium.   If the vehicle is stored, just turn the disconnect off. My batteries are completely disconnected form everything in the trailer when my disconnect is off. Trailers don't always come that way as some still keep the CO/LPG monitor on. When mine is off...it is off.   As far as storage temps, LiFePO4 are good down to -20°C. I would store them in a heated place if it goes below that. You can also get heating mats with a thermostat if power is available.   The way the heaters work, if it's below 0°C, if a charge comes in, it is directed entirely to the heater until the battery gets above 0°C and then it allows the charge to go to the battery.   For my Android tablet I use as a display, I can move it inside my house if I was ever in an area that got super cold.
