Finally done.
1 - You don’t have to drill holes in your truck for the lights.  With long enough wires you can pull various body plugs and run the wires inside your rocker panels.  I used a piece of small rubber hose with a metal wire inside (to keep it stiff) to fish the light wires through.  Modify the body plugs to go back in place afterwards and you have a much cleaner installation (I notched the long ones and made holes on the centers of the rounds ones).  Apply some clear sealer to the plugs and you are done.
Speaking of lights, I used white pods from xlglow that matched the truck.  Amp’s lights are purple
Also, I used plugs for the lights instead of the crimp connectors from AMP.  That way if a light goes out I can replace it easier. I covered the plugs in shrink wrap.
2 - Install the boards on the arms LAST.  This will give you plenty of room to work under the truck during the install.  Amp tells you to do them before wiring which is a mistake.
3 - To remove the BCM connectors:  Pull the white tap up and then squeeze a 2nd tab under the white one while pulling the plug out.  Once you get the hang of it they are easy to remove
4 - My kit had enough wiring harness to go over the coolant tank on the driver’s side.  Amp tells you to go under the truck before the cooling tank which again is a bad idea IMO.
5 - Turn your front tires hard to one side before beginning.  This will give you the needed room to remove the bolts from the front mudflaps and liner to allow you to snake the wires down under the truck.  Don’t forget the liner bolt midways up towards the engine
6 - Pull off your negative battery cable to avoid codes when unplugging the BCM connectors
7 - Amp tells you to use the brake cable boot in the drive’s footwell to get the wires in the cab.  Trucks with an electric parking brake don’t have this.  I used a blank rubber plug near the doorsill under the carpet
8 - I don’t like how Amp tells you to mount the controller but couldn’t come up with a better idea.
Give yourself plenty of time and buy lots and lots of tie wraps, especially the really long ones to go around the frame on the driver’s side.  This was an all weekend project for me but I wanted everything done right.  Properly routing all the wires takes a lot of time.
Finally, prepare to get filthy from the dirty frame wax.  Nasty stuff.
Edited by Aubie_01
  • Like 4
  • 5 weeks later...
Great write up.  It will come in handy when I install mine in the next few weeks!
Thank you very much!
On 10/27/2024 at 10:59 PM, ormandj said:
@Aubie_01 Great write-up. Do you have model on the lights you purchased? Mind grabbing a photo at night with them on?
I used the white XKGlow minipods.
https://store.xkglow.com/catalog/product/motorcycle/accessories/led-pod-single-color-add-on/
In the picture below you can also see the lit footwell mod that I completed using the same lights.
Edited by Aubie_01
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
