I purchased my ‘11 Silverado last May, approximately 76k miles. I’ve noticed while driving, especially when slowing down to maybe turn and then reaccelerating I get a clunk feel. I thought maybe it was the “driveshaft clunk”, but after lubricating the yolk, changing transmission fluid and filter, and replacing U joints (since I had it off), it still happens. From a stop, the shift between gears seem fine, no clunks, really only during downshift and reaccelerating. Could it be a/the solenoid(s), and if so, which one(s)? Any insight is greatly appreciated!
My 2011 does this as well.  has done it since I owned it.  bought it with 40k on it - currently at 136k.  still doing it with no issues.  I assume it's the nature of the beast.
slowdown, turn corner, accelerate and "SLAM" or "CLUNK" - not always - but it happens.   I think it's the computer not knowing what gear to put the tranny in at the specific RPM
Mine does that, only when I'm turning a specific street corner.  Its done it since I bought it in 2019.  I wouldn't worry about it (unless Wysong or some more knowledgeable person than me says otherwise).
Driveline/gear backlash or tie up.  Especially if you have a 6 speed truck.  Normal.  I had a 2012, did it from day one new.
TSB on clunks - temp.xml (nhtsa.gov)
Also, don't lubricate the slip yoke with anything but Dexron VI ATF.  The older trucks 1999-2007 they were able to have a light grease applied to the splines but 07+up they changed the transfer case sealing so grease should NOT be used, only ATF.
Edited by newdude
Is there not a firmware upgrade that resolves it? One would think that if it were related to firmware there would be a fix.
Does it have a split shaft? If so, clean and lube the splines between the front and rear shafts. Keep it clocked to avoid vibration.
When I worked at a Chevy dealer, we would use the GM special lube grease with ptfe, mix a small amount of autotrac oil in the can. Works well.
Thanks for the tip, but no split shaft.
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
