Long story short, I have 2 vehicles waiting on transmissions at the moment.... A 24 L8T w 20k miles & a 2021 Yukon with 49k miles (converter only). The Yukon also has a grinding rear end when its cold every morning which is what I'm after. The dealership has already changed the fluid once before and the problem came back much worse only 6k miles later. The dealer is telling me they're advised to keep changing the fluid until the part fails per a bulletin. The dealership also told me it's a joke & won't fix the issues but have go go "through the process".
I need a corporate contact or a Southeast field engineer, or someone who can do more than GM the CS people. My dealer has been great, but has their hands tied with the rear end repair. They told me to call GM.
My wife and I have wasted probably 30+ hours driving back and forth to 2 different dealers getting these vehicles repaird lately.
Edited by 20SierraL8T24
Added information
3 hours ago, redwngr said:
Have you been through the steps in the back of the owners manual?
Haven't gone that route quite yet.
Dealer is citing 3 attempts required which is lemon law, however mine doesn't qualify for that law anymore. Dealer is essentially agreeing but won't fix it because of the bulletin.
There are some who have added limited slip additive when changing fluid in the SUV diff and solved the cold start groan/noise. The 21+ SUVs don't have the gov lock diff that the trucks have, they have a traditional limited slip with clutches.
I have to wonder with these SUV rear ends if the dealers are actually following the TSB fully, or they are just draining and filling it and sending it on its way.
Here's the TSB - 21-NA-028 1..2
Big thing is the procedure to it.  Get it to temp, drain it, fill it, perform multiple figure 8s in the parking lot then let it cool back down.  If it still moans, repeat.  They even state it can take 2-3 drain and fills to resolve this.
Thank you for your response.
I asked this question when I picked it up this afternoon. They said they do it by the book. It has been flushed twice now with a follow up appointment next week because I'm going to drive it over a thousand miles this weekend.
I however have another question. They're adding an "additive" to make the clutch slip more when cold... Now will my rear end not lock up when I need it to because they're compensating for something else?? Is my rear end not working as designed now?
The additive is a friction modifier.
https://blog.amsoil.com/what-does-a-limited-slip-additive-do/
Dropped the vehicle off again this morning. Latest oil change did absolutely nothing but make the rear end worse.
This is a complete waste of time and my patience is really running thin.
Left the dealer this afternoon after the 3rd fluid change & the grinding is worse than it was when we dropped it off.
I can't believe that GM won't do anything about this. I'm at a loss of words
Try another dealer? Have a conversation with the current dealer that something else HAS to be done.
I've had it at 2 different dealerships. Victory Layne Chevrolet as well as Dixie GMC. Both dealerships have said they can only change the fluids 3 times per TSB unless the part physically fails. I'm worried my wife will get stranded on a busy road and potentially get in an accident when it does lock up.
I filed a BBB auto claim this morning because it has reached the 3rd attempt without resolution threshold.
Le casino Macau est bien connu pour sa collection exceptionnelle de logiciels de jeux. Ils se sont associés à certains des meilleurs développeurs de logiciels du secteur, notamment NetEnt, Betsoft et Play Go, pour n'en citer que quelques-uns. Ces relations garantissent que les joueurs https://macau-casino.info/ peuvent profiter de jeux de la meilleure qualité, qui incluent des visuels époustouflants, des effets sonores réalistes et des interfaces de jeu conviviales. De plus, la bibliothèque de jeux est souvent mise à jour avec de nouveaux titres, ce qui maintient la sélection de jeux fraîche et fascinante.
If it were out of warranty, this would be the route I'd try. However, GM has had me waste my time with 3 fluid changes and after a couple hundred more miles, it's no better as expected. The rear end feels like I have a truck in 4WD on the pavement while turning now.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
