I have a 2024 GMC Sierra 1500 with the fancy po-tailgate. Is there a way to lock the main tailgate? I see how you can lock the middle portion, but can't find a way to lock the tailgate.
Not really understanding what you mean, the tailgate is always locked unless it detects the remote if the remote is not next to the truck it won't open by pressing the button on the gate. I forget the perimeter around the truck for it to dectect the remote.
Edited by Silverado4x4
Son of a gun, i never realized that! I always have my key fob in my pocket when i am near it.
Thanks!
~3 feet from receiver in doors and tailgate
