Good day all….trying to install a camera in my 2025 3500HD. Need a key off unpowered circuit. Been through the left and right fuse boxes and it seems all fuses remained powered. Let the truck sit for a bit to eliminate RAP circuits. Have not tried the engine compartment fuses as I don’t want run a wire though the firewall. What am I missing here?
Thanks for any suggestions!
Chris
2025 Duramax 3500 SRW
You might want to go with a units that attaches to the ODBC port.  I did go with thinkware units,  it has a lot of functionality when the vehicle is parked and monitors the battery voltage and lane drifting.
Anyway the ODBC direction might be a better way.
This thread will help:
Fuse F26 and that auxiliary power pin in picture on the passenger's side fuse box can be used as an ACC source. I used the aux pin for my seat heaters and dash cam.
One other way to do this install is to start with the Upfitter kit. The additional fuse box allows for 4 of the switches to be on all the time or ignition controlled.
I just installed my Blackvue dash cam off this system and it works as expected.
The challenge is going to be installing the upfitter kit which is a bigger job.
Running the camera off the ODBII port is a great idea but in my case, I have a Banks monitor plugged into the port.
The ODBCII is a pass thru but the ODBC is needed for this device as it monitors your vehicles status, park mode, driving mode, low battery etc, but I get the point.
This is the way. Its the same spot I used for both my dash cam as well as the turn-on signal for my underseat amp/ sub combo.
Does this allow your vehicle cameras to monitor the surroundings when it is parked and turn off?
Thats entirely dependent on the dash cam you use. For that feature, it would require a hot at all times feed, in addition to a switched ignition/ accessory feed as discussed above. For mine, it does have a "sentry" mode that has to be connected to B+, as well as the aforementioned ignition circuit.
I parked the my truck after returning from at trip yesterday and left my dash cam switch turned on (by mistake). Tonight I noticed my dash cam was on so I turned it off. I am using AUX 2 for the dash cam and it can be configured to be hot all the time or controlled by the ignition.
Are you referring to the upfitters setup,  if so see below:
@KTDanforth Yes, I have the dashcam hooked up to the AUX 2 switch. It is currently setup as "Always On".
I noticed the camera was on as I passed by the truck at night. I am going to switch these to "Ignition Live" and just leave the AUX 2 button pushed.
I don't want to kill the batteries!
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
