I have 2024 Silverado RST 4 wheel drive 5.3L V8. I am wanting to add footwell lights in the cab. I want the lights to come on and off like the dome light does. I have been researching this and really not getting a clear answer where i can tie into to make this happen. I was looking at the K9 body connector #3 but not really sure if that is correct. Any help or suggestions would be great. Thank you in advance.
BCM X1 pin #1.  It is the same spot that is used for illuminated door sills for refresh GM trucks.
That should get you in a rabbit hole if you search on here.  Good luck.
@Low Down is correct, there is a GM document for the door sill upgrade. Thats where you can get the dome lamp power for the lights. You will need a "Molex" pin to place in the block for the power. I have posted on it several times. Accessing the block is very hard since its under the dash and the farthest one forward. Correct orientation of the Molex pin is very important.
Page 23 and 24 is where the info you seek can be found https://ecom-dam.ext.gm.com/products/documents/isheets_85527849.pdf
@newdude first posted the link in an earlier thread.
Edited by 64BAwagon
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
