Replaced damaged rear park sensor but still get service park assist message. The switch on dash will not light amber. Does any body know the fuse location for the park assist module. Did go over the manual and online but cant find fuse location. Thanks.
You
a) probably need to look at the wiring diagrams to know what fuses are used for it
b) get/use a more advanced code reader, that can get codes from all the system in yourur truck, to find what problem the truck has noticed to turn on that message
Fuses are labeled in the fuse box lids.
Did go over the labels on fuse box lids did not find the parking aid fuses. Guess the module is shared with something else that is labeled. Will need to do what Davester posted buy an advanced code reader and see what the problem is. Now start the search for a code reader. Thanks.
  • 3 weeks later...
On 8/19/2025 at 4:58 AM, davester said:
You
Fuse F18DR in the right instrument panel fuse box.  Labeled "VPM/OBS DET"
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
