Maybe this topic has been asked and covered, i didn't find much. I bought a new 2024 GMC Sierra last year, with a 6.2 and max tow package. I have a 2020 Rockwood MiniLight that came with a tire pressure monitoring system, and the dash mount device. I had new tires put on the camper last year, and the first time i pulled it with the new truck i tried to set up the existing system. For whatever reason, couldn't get them to register. I followed the directions on the trailering app. After that i got thinking, should my truck have come with extra sensors in the glove box? I purchased it out of state, and it was delivered to me, so i never got to ask about it before hand. If the trucks don't typically come with them, well, kinda lame, but ok. I assume i can buy the correct type online that will mate up with the truck trailering app? Everything else works great, pulls like a dream.
On most trims the sensors for TTPMS are a separate order item from the trailering app.
They are only standard on AT4X and Denali Ultimate
Available on AT4 and Denali (without adding other options)
Available on SLE and 3SB version of Elevation (note 1 applies)
Available on SLT (note 2 applies)
1500. Sierra max tow (NHT) is only available on SLE, Elevation (3SB) or SLT.
You have NHT, so trailer sensors would have been extra.
Check the QR code on the bottom of the doorpost of your truck.
If the rpo codes listed include PTT then your dealer owes you a set of sensors.
In 2019 the extra sensors for the trailering package were included. They made them a separate item that had to be added in the 20+ trucks.
On that note. They changed the frequency that the sensors work off of on the trucks tires in the refresh models. I don't know if that applies to the trailer sensors or not. I would think it was changed also.  If you do buy a set I'd make sure the frequency is correct on the ones you buy.
2019-newer all use 433mHz.  For the refresh they changed the operation of the sensors from a manual learn sensor to an auto learn sensor and there in lies the compatibility issue in using a pre-refresh TPMS on a refresh and vice a versa.  They talk to the trucks different than 19-22.
Edited by newdude
Oh ok. All of the past posts I've seen always said the Frq had changed as well with the refresh. Thanks
Did the TTPMS sensors also change to auto learn?
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
