So getting older, hopping up in the bed of my 2024 is a little harder on my knees. While the bumper steps help tremendously in that aspect, I still thought I needed something else.
Cue, Boost Auto and their retractable bumper step kit. Man, it makes it so much easier to get up into the bed now. Knee saver for sure. Its a nice solid unit that retracts nicely up to the bumper, and doesn't look too out of place. When lowered it gives you a foothold about halfway down between the OEM bumper step and the ground. The step pad is customizable a bit for your liking, with different pad designs and colors.
Check out my full install video below.
On 1/13/2026 at 7:22 AM, silveradosid said:
great idea if you live in the south, wouldn't work long in the snow belt
I think it would be OK. Boost Auto is based out of the Chicago Suburbs, plenty of winter weather there. They do pretty rigorous testing and engineering on their products.
On 1/13/2026 at 11:09 AM, johnnyquick said:
Boost auto has excellent products!
Agreed!
I just had their Lumastep M2 installed on my truck. Dont care for the way the guy wired up my engine bay at all Id play hell trying to decipher through it to fix it. The boards seem fine so far. The only thing I dont care for is the fact that the rear of the cab has a curve inward so the boards stick out on the backside.
Byrds,
Do you have pics?
This is from directly above. there are no adjustments on the brackets. The boards were all the way to the rear originally so I moved them more to the middle to try to take some of it out but it didnt help much.
Edited by Byrds8
That don't look right. I'd get a hold of Lumastep and see what's wrong.
I like the steps though.
I had the M2's installed on my 2022 1500 and it looked about the same, just the way the cab curves.
I have a set of M2's coming from Boost Auto for my 2500. I'll see how they look on there.
I did get in touch with BA. They said due to the curvature of the cab, it's the way it's supposed to look. They did say if I slide the boards all the way forward it would take of it out. I just cant have them sitting all the way like that. Would drive me nuts looking off centered.
Let me know how it turns out.
    B07
    B07
  • Who's Online   1 Member, 0 Anonymous, 729 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
