So getting older, hopping up in the bed of my 2024 is a little harder on my knees. While the bumper steps help tremendously in that aspect, I still thought I needed something else.
Cue, Boost Auto and their retractable bumper step kit. Man, it makes it so much easier to get up into the bed now. Knee saver for sure. Its a nice solid unit that retracts nicely up to the bumper, and doesn't look too out of place. When lowered it gives you a foothold about halfway down between the OEM bumper step and the ground. The step pad is customizable a bit for your liking, with different pad designs and colors.
Check out my full install video below.
On 1/13/2026 at 7:22 AM, silveradosid said:
great idea if you live in the south, wouldn't work long in the snow belt
I think it would be OK. Boost Auto is based out of the Chicago Suburbs, plenty of winter weather there. They do pretty rigorous testing and engineering on their products.
On 1/13/2026 at 11:09 AM, johnnyquick said:
Boost auto has excellent products!
Agreed!
I just had their Lumastep M2 installed on my truck. Dont care for the way the guy wired up my engine bay at all Id play hell trying to decipher through it to fix it. The boards seem fine so far. The only thing I dont care for is the fact that the rear of the cab has a curve inward so the boards stick out on the backside.
Byrds,
Do you have pics?
This is from directly above. there are no adjustments on the brackets. The boards were all the way to the rear originally so I moved them more to the middle to try to take some of it out but it didnt help much.
Edited by Byrds8
That don't look right. I'd get a hold of Lumastep and see what's wrong.
I like the steps though.
I had the M2's installed on my 2022 1500 and it looked about the same, just the way the cab curves.
I have a set of M2's coming from Boost Auto for my 2500. I'll see how they look on there.
I did get in touch with BA. They said due to the curvature of the cab, it's the way it's supposed to look. They did say if I slide the boards all the way forward it would take of it out. I just cant have them sitting all the way like that. Would drive me nuts looking off centered.
  • Thanks 1
Let me know how it turns out.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
