IMG_5497.thumb.jpeg.3390ec775066890af1ed7e2e888ea36e.jpegQuick introduction: I have a 2019 Chevy Silverado LT. The truck has Camburg UCA’s., King IBP 3.0 coil over front shocks, King IBP 3.0 rear shocks. Deaver leafs springs, 35” BFG, amp electric steps, and quite a few other additions to the truck.
I wanted to post about my recent experience with re-gearing my truck. Hopefully this will help somebody somewhere because the information that I tried to find is extremely limited.
My gear ratio was 3.23 and I went to 4.56. The company that installed the gears originally put a Hyper-Tech in-line speedometer and gear calibrator on the truck. It worked fantastic driving around town, but once I broke the gears in, I started driving and on the freeway. While on the freeway doing 79 mph I got a notification on the dash that stated truck is governed at 92 miles an hour. Then the throttle was dead (governed)  Keep in mind my speedometer was dead on with GPS. I spoke with Hyper-Tech about this and they stated it’s potentially too big of a gear change. They only know of the in-line calibration working up to 4.10 gears. (That is not confirmed).
Something in the rear end wasn’t talking with the computer in the front end so I bought an edge pulsar LT in-line calibrator thinking that that would work better. I ran into the exact same problem except the governor was now set at 112 MPH (which is the stock setting on that truck). But at 85 miles an hour my driveshaft felt like it was going to detonate. Basically the rear end was turning the driveshaft RPMs as if it was doing 112 mph.
I finally found a company that re-geared a 2019 Chevy Silverado with 4.56 gears and they ran into the exact same issue. The way they ended up fixing it was the truck had to be tuned not performance tuned just tuned so it accepts the new gears.
I’ve been dealing with this problem for about a month now and I finally caught a break two days ago and received that information and had the truck tuned and it drives absolutely perfect shift. Perfect. Everything is like stock.
Hopefully this helps somebody looking for some information. I don’t know if this applies to 2022.5 and up I just know specifically it applies to 2019 through 2022 pre-refresh.
Edited by Luckyfd1
Yes, I wasn’t very specific. lol. ECM/TCM. He was able to unlock both from his laptop. Which I thought was odd because all the ECM and TCM tunes you buy online you have to get to those units to unlock them, but I guess there’s other ways. IDK?
Yeah, I had always heard that you have to "unlock" the ECM and TCM to program them, there are units that can be bought for that now but I think they only allow there own tunes.
It would be GREAT if you could find out what program etc he was using.
Glad you finally got it figured out, how is the performance now and any info on cruise RPM at like 75mph?
Is gas mileage still good?
Thanks! I will ask the guy and post it on here. So I didn’t have him delete anything or change anything except for the tire size and the gear modification. The truck is getting a Whipple, long tube, and DOD delete kit, larger cam. So we’re gonna have to tune the truck after these parts are installed. But as of right now, I can’t tell you how amazing the gear change is. For those who have changed gears before sometimes it feels like it didn’t change anything at all… I still have really good RPMs on the freeway and it just wants to pull the tires off on the surface streets.
Come on vacation leave on probation that’s the Vegas motto
besides bad decisions, make better stories!
Edited by Luckyfd1
  • Haha 2
That’s a good deal. 1/2 off almost!
my house is kinda like the federal government. I get a certain amount to spend every year, if I don’t spend it, I won’t get as much the next year. I’m at the end of the fiscal year so I’m dumping money!
Edited by Luckyfd1
Appreciate the info Luckyfd1, I too have a 2019 Silverado 5.3l, but it's a RST, I Have Cognito upper control arms with 3.5 Rough Country coilovers and almost 35" in tires but not quite. I've been looking for some one to tune or calibrate the speedometer odometer to match tire size for better shift points. I've also am considering the hyper tech speedometer odometer calibration programmers but now that you mentioned the freeway issues, I'm glad I haven't pulled the trigger. Would you be willing to give me some info as to where you had the calibration done. And the cost. I'm in the L.A area 562 area code. Thanks
Except in Utah, where the Vegas tag line is "What happens in Vegas stays in Vegas,.... except STDs.  That ****** will haunt you for life."
  • Haha 1
That's not the federal government fiscal policy.  That's a government agency policy.  The federal government policy is to spend, spend, spend, even when they'd don't have the money.
Those tires would be called "Metric 35s."  Since you like Rough Country, look into their catalog.  They have a speedo calibration device.  Plug it into your computer, run the install wizard, tell it your OE tire size and then your new tire size, and it'll write the code.  You then take it to your truck, remove 1 plug under the drivers side dash, plug the RC wire harness into that port, insert plug you just remove into the RC harness, and then tuck the rest of the wires away.  The entire process should take you less than an hour.  I've been running the RC speedometer calibration device for over 2 years.  No problems, yet (knock on wood).
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
