On 2/6/2026 at 6:18 PM, Luckyfd1 said:
In my case…going from 3.23 - 4.56, could that 4.56 be too much for the truck to handle?
Too much for which part? Simple answer, no, so long as you can correct the electronics so that everything works and you understand the new physics of a faster spinning driveshaft.
...but at higher speeds the drive shaft RPM was too high...
Was there a specific symptom that you noticed?
Meaning you can “trick” the ECM/TCM but there’s nothing you can do about the drive shaft spin… what I’m getting at is the tune can’t do anything about the drive shaft RPM it only makes the computer interpret it differently. The truck is now limited to a lower top speed??? 85 is the new 112… ?
All correct, but the computer doesn't specifically monitor or care what the driveshaft RPM is beyond a speed signal so that the truck knows what to put on the speedometer. This RPM, mph, speed signa, etc. is totally outside of an actual MPH/RPM spin physical limit of the mechanical components.
No 'in line tuner' will ever change the physics of a new gear set.
The driveshaft, and everything else up stream of the differential, the engine and transmission are turning faster at any given speed than they were before the gear swap. The physical limits of these rotational forces are just that - physical limits. No electronic wizardry will fix that. Again, the internet claims that higher rotational speed of the driveshaft is a potential for failure. I've seen references of give or take around 120mph WITH THE ORIGINAL GEAR SET. The speed (mph) you should be concerned with driveshaft failure is now lower, how much is unknown, because there isn't a specific number that the driveshaft would fail at before. This is all internet rumor with anecdotal reports.
this was prior to the last tune that fixed my truck. I was curious why the inline models didn’t work.
does that make sense?
The truck gets signals from wheel speed sensors and vehicle speed sensors (at a minimum). Presumably, the in line tuner corrects one of those so that the speedometer reads correctly. The software might allow a degree of difference between all the speed signals before it says one of these is wrong and starts causing problems. A full tune could correct ALL signals.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
