If that's how your owners manual describes how it works, then I believe some people have put in a trailer plug so it tricks the truck into thinking a trailer is connected (not just the physical plug, but also w some connections [ie, resistors] so the truck senses that trailer lights are there).
Yes, the plug has to make the truck think the lights are there, that's how the truck "knows" a trailer is attached.  So the plug would need to have some resistors (of the correct size/watts) for the running lights and brake/turn signals.
I got my cameras to come on all the time... with turn signals.
Sort of a result of the Diode Dynamics C1R that I am running in the hitch. It is plugged into the 7 pin system. The truck thinks I have a trailer connected.
I am using this C1R since I am blocking my 3rd brake light with my rooftop tent.
Here is a link:
https://www.diodedynamics.com/hitchmount-led-pod-reverse-kit.html?srsltid=AfmBOoqOqHooGdMTtAsBhB2fa6UxZovj80P1trAmT1Ph9d4AwNLdR6hv
Is there some sort of disadvantage to having the cameras on when not towing?
What about the truck thinking there is a trailer attached?
My Hyundai cameras come on when turn signals on. Towing or not.
Why would GM not do this too?
Removal of the C1R takes about 1 minute. It just unplugs and there is a cap that goes over the connector to keep the dirt out.
The main wiring loom that comes with the unit stays put.
I have my pin lock holding the unit in-place and so no one can steal it.
I just unlock the pin, and slide the C1R out and unplug it. Then I slide my hitch into the receiver and pin it.
It couldn't get easier and the light is super bright as aa back up light and brake light.
The same thing could be done with those tailgate strip lights and I think the truck would see them as a trailer as well. Any light that sits on the 7 pin connector should trigger the truck to think a trailer is connected.
Sort of like this link:
https://www.actiontrucks.com/product-detail/RCS78849/multi-function-led?gad_source=1&gad_campaignid=22638002763&gbraid=0AAAAADnotY3_v0jtgfK-hp22MFl7amrLK
Another side affect is that the rear cross traffic alert gets turned off as well. So the truck doesn't slam on the brakes when backing up and it sees something.
I have a trailer lights checker I plugged into the 7 way connector in the bed of my truck that has the 5th wheel/gooseneck hitch. It gave the camera side view with the turn signal on just like having a trailer connected but it disabled the rear bumper sensors. I would rather have the rear sensors working.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
