Hello, has anyone here used any of these three fender flares on their 2014 Sierra?
GM OEM:
19303664 - Genuine GM Parts
Bushwacker:
Bushwacker Extend A Fender Flares 40100-02 | RealTruck
PSI:
2014 GMC Sierra 1500 Extension Style Smooth Fender Flares
I am less concerned with the additional width and more looking for the vertical coverage. I know I will need to remove the existing mud flaps for any of these.
Thanks for any opinons.
GM OEM:
Bushwacker:
PSI:
The GM ones aren't "GM OEM" just to be clear on that.  They are part numbered for GM but are EGR USA fender flares.
ALSO.  19303664 is discontinued.  So you won't be able to get those anymore unless you can find a set somewhere for sale.  The one site you linked shows out of stock because they are no longer available.
Long story short, I bought those discontinued GM ones back when they were still available. I don't recall how much but it was less than $300 I think. I have a Silverado instead of a Sierra. I bought them because I accidentally customized my front right fender and body shop was estimating $8-900 or possibly more to fix the damage. I took a chance on the flares and they covered the damage completely.
They were a bit challenging fitting the rubber lip all the way around the outer edge and getting it to stay in place. But they came out perfectly. As far as coverage, the bottom part goes right around the lip of the wheel well so they cover quite a bit.
Just to add, I installed these in Dec 2021 and they still look decent
Edited by mikeyk101
I used Rough country pocket flares on my 2014 Silverado. I really like the look.
Ă—
Ă—
