NAV and 6 disk changer in a Silverado
I just finished my install of the navigation unit/amp and most everything works great. I am taking it in tomorrow to have the Theftlock unlocked. The only problem I have is that now the RSA will not work. Is this a common problem?
<{POST_SNAPBACK}>
nothing should work till the theftlock is unlocked, but all should work with the key in the acc position, the theftlock is not locked up untill the key is in run position
<{POST_SNAPBACK}>
I can make the Nav unit work by bypassing the TheftLock, but the RSA still won't work. Also, I took the truck to the dealer today and the tech worked on it for 30 minutes before giving up and saying that he could not unlock it. Has anyone else had this trouble with the dealer? I feel that the HU is communicating with the BCM correctly, as I'm getting the GMC logo on start-up. I'm not giving up yet.
  • Replies 923
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Somewhere in this thread there is a Tech-II procedure to unlock the HU. If your HU is not defective then I would wonder if the dealer-tech followed the procedure exactly.
If your RSA connections are secure, you could try a data bus jumper wire between the HU and the RSA. Power, ground, and data bus are the key wires here.
I finally secured another lux amp and so far no problems. Still waiting on a DVD to play with the nav functions.
Great post!  LOTS of information.  But I have a question about the VSS connection.
I'm planning to purchase a non-lux TNR for my 2003 Yukon and and was wondering if anybody knows what the VSS is actually used for?  Is it just to let the nav system know that the vehicle is moving, or that it is moving a certain speed?
One post around page 12 or 13 mentioned adding a bypass switch to temporarily disconnect the VSS which would allow you to program the nav while moving.  What I'm wanting to see is if there's another way "trick" the nav into thinking the VSS is connected, but still be able to program a destination without adding a switch.
If the nav uses actual vehicle speed to compensate for slow GPS updating, then this is probably not possible.  But if the VSS is actually a discrete of some sort, then it should be able to be bypassed.  Anybody got any ideas?
Thanks in advance for the info.
<{POST_SNAPBACK}>
The VSS helps make the navigation faster and smoother, thus adding accuracy. It also keeps the nav working in low or poor GPS signal areas. Adding the switch is only needed if you want to be able to change or add destinations while the vehicle is in motion.
<{POST_SNAPBACK}>
Thanks, I guess I'll just add the VSS switch.
Also, I didn't see too much info on the Rear Seat Audio in this thread. If I'm adding the Nav and CDX to my Non-Lux Bose system, is there anything special I need to do to retain the RSA? Is the CDX compatible with RSA as well? Thanks.
<{POST_SNAPBACK}>
Yes, the Nav HU is compatible with both the CDX and RSA (and RSE) and there is nothing extra you will have to do for the RSA.
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Nav units are not supported in service programming (factory installed or not)) so the tech may have to call tech line for the proper procedure and some of the TNR's are not unlockable if not in the original host vehicle. As far as the RSA, it should work when you bypassed the theftlock. Does the RSA power up and just not play or does it do nothing. I'm guessing the RSA is not getting the databus signal, you can check it at the RSA connector and it should show voltage around 5 volts
Have the Tech try this. Most of them are not aware of the UM8 radio procedures.
Radio Setup With RPO UM8
Radio Theft Procedure
Complete the following procedure, using a scan tool, in order to properly set up communication:
At the Main Menu screen, select: Diagnostics.
At the Vehicle Identification screen, select the following options:
Model Year
LD Trk, MPV, Incomplete
At the System Selection Menu screen, select: Body
At the Vehicle Identification screen, select the following:
Appropriate model
Appropriate Air Conditioning
Navigation Radio
At the Body Screen, select: Navigation Radio.
At the Radio screen, select: Special Functions.
At the Special Functions screen, select: VIN Relearn.
At the VIN Relearn screen, the scan tool will display "Do you want to clear radio theft information?"
To begin clearing, press the soft touch key on the top right of the scan tool. The scan tool will display "Clearing Radio Theft in Progress."
Press EXIT on the scan tool and cycle the ignition.
Important
The radio theft will learn the VIN. Without learning the VIN, the radio will display a locked message.
Model Year
Appropriate model
Navigation Radio
Important
<{POST_SNAPBACK}>
This is the same procedure that I got from another forum. The problem is that under a 2003 GMC, when you are supposed to select "Navigation Radio", it doesn't give you that as a choice. He even tried going in under a 2004 model, which allowed him to choose "Navigation Radio" in that step and it allowed him to move one more step, but "Special Functions" never came up. He says he belives that the radio isn't communicating.
Since I posted in this thread nearly a year ago, you have all convinced me to go ahead and finally upgrade.
I have a non-lux and will be getting the TS Nav eventually. I have gutted my sound system, bose drivers that is, and running rears (infinity ref) off the bose amp and fronts and 10" subs off a 4x200 amp, interfacing using a PAC OEM-1. This sounds very nice. In playing around, I can say that the weak part of the BOZO is the drivers, which resembled chinese crackers I ate recently. Just replacing them with hi-efficiency infinity made a world of difference, the best $150 you can spend. If you do nothing else, do this.
I did a complete sound deadening of the vehicle, killing 12 dB of road and engine noise (2500HD D-Max). Even the bozo "bass cube" sounded better (not good yet) after that.
Quick one:
Is there a harness wire that would work well as an amp trigger, ie 12V when stereo is switched on? I found one that is 12V ignition, but would prefer a trigger that keeps the amp off if the HU is off.
THANKS
I guess the answer is no, looking at a previous post. But now I am really confused. Several Nav units on EBAY. All of them say that the ...287 is for non Y91 vehicles, and the ...531 is for Y91 vehicles. My head is spinning, all posts here say just the opposite.
here is a 531:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
"Works in vehicles without the Y91 option"
the others follow suit.
HELP!
Because GM feels the need to have identical parts with different part numbers, you will find many different TNR part numbers now
TNR Radios:
10377531 lux 15230099 (newest number to supercede 7511) and 15118439
are other [identical to 7531] lux units
LUX-Y91 touchscreen # 15230099, 10377531, and maybe 15118439 LUX UNITS
1037287 - non-lux
10397545 and 15120706 [identical to 7827] non-lux
Non-LUX touchscreen # 10397545, 15120706
10377287 15120706 and 10397545 - TNR Non-LUX Amp 5600 series BOSE amp
I understand all of that. Am I backwards? Isn't Y91 synonomous with "lux"?
...287=non-lux=non Y91
...531=lux=Y91
Do I have this correct? If so, why is everyone on E-bay confused?
...531=lux=Y91
<{POST_SNAPBACK}>
Y91 is the "Lux" Bose setup
...287 is non-lux
...531 is lux / Y91
You have it right, the sellers on ebay don't really know, one person listed it that way then everybody seen that and started listing that same info on their auctions not knowning weather it was correct or incorrect info and now they have everybody screwed up.
I sold my old IRN on ebay and had it listed as a non-lux non-Y91 with the right part number and the man who bought it installed it in a 2005 Yukon with Y91 and it didn't have any sound. He thought I would refund his money because he believed the other seller's listings and thought it would work even after my listing said it wouldn't.
Model Year
Appropriate model
Navigation Radio
Important
I tried this on a 2003 :cry: Silverado and it worked fine. Can't see any reason why GMC should be any different? Sorry it didn't work.
Hi Everyone. I came across this forum tonight, and it has a lot of good information. Thanks. Here's my situation. (Let me preface by saying I have an '03 Tahoe Z71, non-lux amp.
I purchased the "non-touchscreen" nav radio from a reputable ebayer who stated he could program the radio for either LUX or NON-LUX applications. He works (supposedly) for GM. I received the radio, hooked it up and it worked 50/50. I had sound but there was a horrible ground loop. Buzzing, and static on the speakers even when the car was off/doors open. Seller has been very cooperative and said he wasn't sure of the issue.
Basically, what I want to do is get the LUX amp, make the necessary modifications, and have him program the radio back to LUX.
Has anyone ever heard of this radio being able to work in both LUX and non-LUX applications? The radio model is: 15204335
Can someone tell me the part number of the LUX amp I should get? Thanks.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 580 Guests (See full list)
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
