NAV and 6 disk changer in a Silverado
Here's an adapter for iPod for GM.
http://www.usaspec.com/ipodgm.htm
I haven't used it so I'm not sure how well it works, but it sounds like you can control iPod using the stock HU.
<{POST_SNAPBACK}>
Be aware that if you use this adapter that you cannot also add a CD Changer.
Uses CD Changer Port, If Vehicle has existing CD Changer it must be disconnected.
Klaus
<{POST_SNAPBACK}>
this is from the PAC, it says you can have the cd changer and it will still work.
The AAI-GM12 allows direct interface of any preamp level audio source to a 2003 GM Class II factory radio with a slave unit, eliminating the need for sound degrading solutions like an FM modulator. The AAI-GM12 interface inputs sources from units such as a DVD, VCP, MP3, Satellite Radio or Play Station.
• Lower cost and higher quality sound than a FM modulator.
• Comes with a three position switch which allows you to switch between two auxiliary inputs and the factory slave unit.
• High quality audio isolation IC eliminates engine noise.
• Internal CMOS electronic switching for long term reliability.
Requirements: 2003-2005 SUV’s and trucks with RDS radios (Class II radios). The SUV or truck must have a factory external XM receiver or factory DVD Rear Seat Entertainment (RSE) or factory/aftermarket CD changer (factory 6 disc changer built in the radio does not qualify). Currently only the Escalade, or Denali's have a separate 6 disc changers. Vehicles with optional Navigation radio with 6 disc changer in center console also qualify. Please note that the slave unit must continuously be playing or if XM or DVD, must be on and playing for the AAI-GM12 to work
  • Replies 923
Hey guys, I finished my install of the NON-LUX TNR on my truck and the cd changer is on the way.... but i think the wiring diagram is for the y91 pin setup rather than the nonlux wire arrangement. Please help me out.
<{POST_SNAPBACK}>
If you mean the wiring for the CDX, it is the same for both setups and even the non-Bose headunits
ok, thanks! You guys arn't hooking up the wire for panel dimming?
<{POST_SNAPBACK}>
the dimming is all done through the data bus wire on the 03's and up
Klaus and others. . . Thanks for the inputs. I've passed them along to my local car audio installer. He wasn't familiar with the products and is checking them out for me. It sounds like the suggestions you gave me will make it work. I really appreciate it.
Bill
What is the correct number for the CD Changer. I need to get the right one with the metal tabs on the side not the plastic push pins.
<{POST_SNAPBACK}>
The old part number 15055250 comes up as invalid.
<{POST_SNAPBACK}>
15055250 is one of them for the 03 and up with metal tabs. most places can cross ref with that no.
Why GM went this route for '05 with having a TNR model that doesn't allow for the addition of an external slave 6-disc CD changer on the Tahoe/Suburban/Yukon (and apparently H2, too) is beyond me...especially since Denali and Escalade TNR models allow for (if not already come with) the external slave changer.  I mean, IIRC--the '05 Tahoe/Suburbans that come with TNR units do not offer a 6-disc CD changer option...meaning (and please correct me if I'm wrong) that if you wanted to listen to the factory CD you had to first eject the nav disc from the TNR unit, then load the audio CD into the TNR.
All the TNR's will accept the CDX if you add it. The tahoe's Yukon, and Suburban just didn't have it as an option, but it still can be added to the TNR's and same way we added it to the IRN's in the trucks.
Okay, that's definitely reasonable...but why GM doesn't/didn't offer it (factory slave CD changer) in combination w/ the TNR as a factory-installed option on the '05 Tahoe/Yukon/Suburban is beyond me... :seeya:
Must be GM's way of distinguishing option content between Denali/Escalade and the "lesser" Tahoe/Suburban/Yukon...
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
You might try part# 15122617
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Does that one have the metal tabs on the side.
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Yes it does. Its the one I bought for My Yukon
Anyone by any chance been keeping
track of all the part numbers for the Lux / Non-Lux, INR / TNR radios?
Care to share?
Thanks
OK I put in my two cents worth........
10377531 - TNR LUX - SUPERCEDED by 15230099
15230099 - TNR LUX - SUPERCEDES 10377531
(FYI - info gathered from Delphi Distributor Model Electronics)
7531 - Thru 2004?
0099 - 2005 up?
Ok. I installed the Head Unit. Where do you mount the antenna. I saw one scematic of where it supposedly goes. I cant get the dash apart. Does it really matters where it goes and where did everyone else do it. Right now I have it just dangling in the back of the radio till I get the theftlock turned off next week. Let me know so I can make sure it works.
    goetzmann
    goetzmann
  • Who's Online   5 Members, 1 Anonymous, 561 Guests (See full list)
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
