NAV and 6 disk changer in a Silverado
I got my non-lux touch screen head unit installed and it works great. I have not yet installed the VSS wire though. Right now it works pretty good though. Does anyone know the part number for the manual on how to use this thing though. I cant figure out all the features on it. Let me know if anyone can help.
<{POST_SNAPBACK}>
WWW.HELM.COM go to "Service Publications" > "aftermarket"
(800) 782-4356
  • Replies 923
Go to:
http://www.mygmlink.com
Sign up to get an account, then add your vehicle type (and/or a vehicle that comes with the Nav unit). Once you have done that, click on the "vehicle home" button. Next, click on "Glovebox" on the left. On the next page, click on Owner's & Service Manuals. You should now see links to Adobe Acrobat downloadable versions of the owner's manual and the supplimental navigation manual.
Klaus
I know a bunch of people have been asking me, and i think they are all from this thread..:crackup:. But i have another AMP up on Ebay, tested with the NAV and 100% functional....I will have another next week. MAn, these are getting tough to get a hold of. I cant believe this thread is almost a year old....jeeeeez
That's good news. Hope I win. I don't have a DVD yet but the HU works great when the amp works. It works about every other start up and still no theft lock so I guess the HU was a new unit. I wonder how many people have used this thread and the one on Avalanche to upgrade their trucks/SUV's.
All,
Do these LUX amps come pre-programmed based upon model number if you buy them new from a distributor? In other words, if I went with the 454 amp, that I believe is the Denali part number, will this be pre-programmed to work with the Denali? I'm planning on putting it in an '05 Tahoe.
Thanks,
Brad
nothing will be programmed if you buy it new. It will come sort of like a floppy disk, ready for loading. The best method is to find one thats pulled from a working vehicle, that way there is no question, plus its a hell of a lot cheaper. In my experience, i cant tell the difference between an AMP programmed for say, an Escalade EXT and one programmed for a Yukon Denali. I know that there are a couple extra speakers in a Yukon, but the sound seems to balance itself nicely.
Sperry, Linda, anyone............
Why doesn't the "brand" logo (GMC) come up on my nav screen (just very briefly on start)?
When is it supposed to be displayed or what are you supposed to do to get it to display the logo? I thought that it stayed on when the radio was off.
Thanks
(the unit is a 0099 brand new in the Delphi sealed box)
The NAV should read the vehicles VIN number and make a determination what vehicle its in, then display that vehicles logo. What does yours display when you cycle on the power?
<{POST_SNAPBACK}>
Comes on very briefly with the GMC logo, and if the radio is off, it just shows the dark screen with the clock is displayed.
I thought that the logo was displayed while the radio was off.
The install went great, I removed the dash cover (piece of cake, due to taking my time). Found several loose pieces parts and wire harnesses gone awry, so I got to tighten and tidy up some stuff while I was in there.
Only casualty was the dag blasted light sensor. Ordered a new one $24.
Ok I got bad news...My radio has worked from day 1 which was around thanksgiving time...today after work I come out to the truck and no sound...it worked fine like normal on the way to work but nothing now...I had my data wire tied to the power for the rear concole so in order for me to get sound I always had to turn on the rear seat controls..now when i do that i dont get anything...is this maybe a wire loose or did something go wrong? like i said, it worked fine all the way up until i took the key out this morning...very weird....all my steering functions work except volume...which wire is responsible for that ?
<{POST_SNAPBACK}>
Does everything work except the sound, including no chimes? Mine is now working every two or three start-ups, then no sound. When I have no sound, all other functions work, so I know my data wire is good. I think I messed up my amp. If your data wire connection is bad you would lose all functions your amp now controls. I know I'm cool for tunes when I put the key in and hear chimes.
Guys, I highly suggest you check your connections, and follow the schematic carefully. The data wire should come from PIN "A1" at the HU in my opinion, and all your connections that are not direct pins inserted into the harness should all be soldered. The VSS wire should be soldered at the Instrument cluster harness PIN "A4". The data wire should be soldered at the HU harness PIN "A1", then ran to the AMP harness. I know theoretically the data wire should be the same through out the system, but i have heard of a few cases like "4x4TX" is decribing when the data wire is connected to the RSA instead of the HU. If your AMP is good, you follow the schematic carefully, and solder all your connections, you should never have a problem. This is a moderately skilled upgrade that requires a little patience. Dont let your excitement of completing the project overshadow doing the job thoroughly.
<{POST_SNAPBACK}>
I connected data to A1, all my connections are soldered and shrink wrapped, I checked wiring multiple times, and took my time...I'm in no hurry for screw-ups, for whatever it's worth...
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
