NAV and 6 disk changer in a Silverado
I Have just finished installing a Nav system in my 2004 ext silverado, I have a 6 CD Changer I want to install. I have read every post in this tread and I still need some help. According to the diagram (9 pin to 12 pin Aux cd harness) I need to soldered 3 wires to the 24 way harness (the Dark green to A1, the Orange to B1, and the Black to A12). OK here is my first question, is this to be done at the raido end or the Amp end? Next the diagram the wires going to the 12 pin harness at the raido ( Tan to K, Brown to J, and Light green to H) OK heres my second question, do I remove the existing wires in the 12 pin harness or do I solder these also.
Any advice would realy help
Thank Ypou
  • Replies 923
Thank Ypou
I connected data to A1, all my connections are soldered and shrink wrapped, I checked wiring multiple times, and took my time...I'm in no hurry for screw-ups, for whatever it's worth...
<{POST_SNAPBACK}>
Sounds like you did a good job, I would have to put my money on a failed or failing AMP, or a failed or failing HU.
Make sure that your pin connectors are not backing out when the connector is plugged to the amp. Remove the console glove box and and the rear of the console, turn on your radio and push the connector and see if anything changes. If you get sound you have a weak connection on one or more of your pins. This happen to me for one speaker when I did the swap, had a pin not staying in place when connected. Hope this might help anyone who just lost sound or it comes and goes.
Jim :cheers:
Thank Ypou
<{POST_SNAPBACK}>
Yeah just cut into them and solder them. I had the same problem. I have a silverado ss with xm radio. I did that and everything works great.
Great post! LOTS of information. But I have a question about the VSS connection.
I'm planning to purchase a non-lux TNR for my 2003 Yukon and and was wondering if anybody knows what the VSS is actually used for? Is it just to let the nav system know that the vehicle is moving, or that it is moving a certain speed?
One post around page 12 or 13 mentioned adding a bypass switch to temporarily disconnect the VSS which would allow you to program the nav while moving. What I'm wanting to see is if there's another way "trick" the nav into thinking the VSS is connected, but still be able to program a destination without adding a switch.
If the nav uses actual vehicle speed to compensate for slow GPS updating, then this is probably not possible. But if the VSS is actually a discrete of some sort, then it should be able to be bypassed. Anybody got any ideas?
Thanks in advance for the info.
<{POST_SNAPBACK}>
The VSS helps make the navigation faster and smoother, thus adding accuracy. It also keeps the nav working in low or poor GPS signal areas. Adding the switch is only needed if you want to be able to change or add destinations while the vehicle is in motion.
This is definetly true. Before I had the VSS wire hooked up if I would be driving real fast it would say take next exit 1/4 mile and I would already be at the exit. It works a lot better now.
I just finished my install of the navigation unit/amp and most everything works great. I am taking it in tomorrow to have the Theftlock unlocked. The only problem I have is that now the RSA will not work. Is this a common problem?
<{POST_SNAPBACK}>
nothing should work till the theftlock is unlocked, but all should work with the key in the acc position, the theftlock is not locked up untill the key is in run position
Hey, Im helping a friend install an amp an subs tommrow, for the LOC should we tap at the radio or rear speakers? This is a non bose 2003 silverado. ext cab. I would prefer to tap at the radio. i also heard that the rear speakers do not have enough bass to tap there is that true?
also, if i tap at the radio, tap the front or back speakers?
<{POST_SNAPBACK}>
If it is a non-Bose then you can tap at the headunit, and use the rear speakers.
your correct that the rears do not produce as much bass as the fronts, but thats i because of the speakers design and has nothing to do with the signal going to them.
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Thanks, I guess I'll just add the VSS switch.
Also, I didn't see too much info on the Rear Seat Audio in this thread. If I'm adding the Nav and CDX to my Non-Lux Bose system, is there anything special I need to do to retain the RSA? Is the CDX compatible with RSA as well? Thanks.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 547 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
