NAV and 6 disk changer in a Silverado
Yep! you do have to rewire the `burb amp connectors.
For those of you who feel you had enough viewing here, perhaps you would enjoy a little reading over HERE only 900 + posts (to date) of my topic there.
Edit: Updated it - The previous one was intended for the amp connectors only. As it grew older, I sidelined the RSA connections, some folks were asking about. Try this one, It has some corrections
New X-Ref Chart 12-31-04 (Prem-To-Lux_Amp_Conn_Rewire.ZIP)
HTH!
  • Replies 923
ahh ok so the vss is basicly for the navigation map while im driving for the icon to move smoothly and not stop and skip what about the gps antenna dose that have to be mounted under the dash cause i really hate to take the dash pad off  :seeya: and also what about the cdx error i capped off a couple of wires when i installed the 6disc dose one of those wires need to be conected to the wire harness?please help me! lol
Not 100% sure, but i dont think the non-lux NAVs have a CDX option on them. Thats is probably why you are getting the error. Thats what i have heard anyhow. You need to go full LUXURY to successfuly add the CDX option i think. The wires you capped off are speaker wires and have nothing to do with functionality. Thats all done through the class II wire. By toggling through on your steering wheel to reach the CDX, you are sort of opening a "backdoor" to it as the BCM will recognize another device, however the HU will not. Thats my best guess.
well i got the cd changer working! when i first tested it the nav was not unlocked i just did the little trick that lets you play with it till you start it or shut the truck off but now that the dealer did the unlock it works perfect with the cdx button so now im just waiting on the gps antenna from gmpartsdirect and as for the vss wire where do i get that wire from?
BB - the "Non-Bose 10351123" nav.. `Wished it was true! It comes back as a Rendezvoux HU. (Or was it a Ranier?) anyway, whichever one, there was no base option for the particular model!
External amp only systems... Hmmmm.
Any other info?
Any other info?
<{POST_SNAPBACK}>
It is from a Rendezvoux and so is part #10352079.
I have one installed In my 04 Silverado regular cab and I don't have the Bose system since GM wouldn't put it in a regular cab.
The HU looks and fuctions just like the non-lux Bose one (15204334) but in has its own amp built in. It even says "sound by Bose" with the Bowtie on the start up screen. It does work with Onstar, XM, steering wheel controls, and the 6 disc changer, I don't know about RSA or RSE since I don't have that but I would guess it would.
I bought it from Model electronics Inc. for $1318.30 (#10352079)
The 10351123 is also the same but was not in stock at the time.
I can send you pics if you would like to see it.
OK, that's interesting news!
BTW, the 15204334 is a Lux INR! Same as with the 15204335. The 4335 has the radio/aux window in the nav screen if you want it.
<{POST_SNAPBACK}>
The 10352079 has the radio/aux window also right under the compass window.
All after the 4334 have that, that I have seen.
OK, the 2079 is an INR.. Was the other P/N they were out of stock an INR or TNR?
Ok… I went over this post and this is what I think I need…
I just purchased (Today) a 2004 Envoy XUV with the 1SC package and UB1 radio. I want to install the TNR…
What I need is:
10377287 nav unit
15135178 GPS Antenna.
If I want to use the other system I need
1037751 nav unit
Amp
Is this correct?
Thanks
Steve
I have been reading some your comments on adding a Navigation unit to various GM trucks and SUV's. I have tried some of the part #'s and they appear to be discountinued the changer in particular. asfar as rewiring is there more than the 3 wires to the remote changer?also is there a nonlux INR nav or its just the TNR ver. only?
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 826 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
