leveling help
im trying to fit 285/75/R16 BFG All Terrain KO's on my 2000 Extended Cab 2wd sierra. What is the easiest way to lift the fron to make it level or even a little bull dogged to the back, so I can fit them?
You may have to buy a two inch lift kit as there are no torsion bars to crank on a 2wd.
is it possible to just level the front with the back for cheaper than a 3 inch body lift?
I used 2" coil spring spacers to level my 2000 Silverado 2wd. They were made by Daystar. Installing them was pretty simple taking only a couple of hours in the driveway.
