FM Modulated MP3 Changer
Hey all,
I got a JVC 12 disc MP3 changer that I recently hooked up but I have noticed the sound quality isn't what I expected. The first time I hooked it up I put the changer under the rear seat (ext cab) with the wires running down the middle of the truck under the centre console. The FM modulator thingy was under the dash right in front of the centre console. With this setup I would get interference that would get louder and higher pitched as I accelerated.
I pulled it all apart and moved the FM modulator thingy to the glove box and left the changer where it was. Now the noise is less loud but I have another high pitched noise that is constant. I have the correct antenna adapters and tried moving the power and constant wires too, but, it is not what I expected. My buddy has a Mercury Cougar same MP3 changer and his has much better sound, virtually no interference. The only thing I can think of is his car is a manual, I am not sure if running the wire to the changer down the transmission hump is a good idea. Can anyone suggest something I could try to improve the sound quality (without buying a new HU and Changer :seeya: )?
I was looking at using the AUX port in my factory HU but from what I was told you can't use it with a changer but it would work with a HD MP3 player
Thanks in advance
sD
  • 1 month later...
Does the radio have a provision to hook up a cd changer. if it has that Pbus connector in the back then you could use that. I did that with my Pioneer radio when using my mp3 player in my ranger.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
