yet another coolant leak...
has anybody had a coolant leak on a 5.3L towards the front of the engine? this is the 3rd coolant leak that my truck has had (42500 miles), and im not happy...i cant locate the origin of the leak, but it starts somewhere in the lower front of the engine, and it runs all along the bottom of the oil pan to the drain plug...i dont know how long its been like this, since i had to take the skid plates off to see it...some of the steering components are a nice Dexcool orange also...
the first two coolant leaks ("porosity" in the engine head, and a leaking freeze plug) were covered under warranty...this one, im not so sure...
what would you do?
thanks for the replies...i looked under there, and it doesnt look like the leak is that far up the engine...it looks like the bottom of the timing chain cover was leaking at some time...
99%of the time it is the waterpump gaskets,and it is very hard to see it actually leaking from the gaskets themselves,but a sure sign of it is when it runs down and onto the oil pan.I've replaced many of the gaskets very easy to do.Good luck
Since the water pump bolts up in front of the timing cover, it may give the illusion that the timing cover is leaking. If the timing cover were to leak, it would leak oil, not coolant.
Is this all that common? I seem to have the same leak. Thought it was the water pump, but hopefully just the gasket. I will have to check it out i guess.
Scott
    • 3.47 Kroger’s in Montgomery Tx
    • I can relate. 3 years ago I did that on my Avalanche. I was sore for a week. The only maintenance I do myself now is drop and fill on the transmission on my Honda’s. It’s just too easy. My yard work with my walks in the morning will be enough now I passed 70. The contributing factor is the heat in Texas. You just have to pace yourself.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
