Your Cell Phone Number is in Danger
kirkRHughes
Starting Jan 1, 2005, all cell phone numbers will be made public to telemarketing firms. So this means as of Jan 1, your cell phone may start ringing off the hook with telemarketers, but unlike your home phone, most of you pay for your incoming calls. These telemarketers will eat up your free minutes and end up costing you money in the long run.
According to the National Do Not Call List, you have until Dec. 15th 2004 to get on the national "Do not call list" for cell phones. They said that you need to call 1-888-382-1222 from the cell phone that you wish to have put on the "do not call list" to be put on the list. They also said you can do it online at www.donotcall.gov
link
Well I just added my cell # to the list, but oh how I hope one of them does call ... I'm gonna let em have it! LOL
Telemarketers :cheers:
I pray for the day a Telemarketer callsme on my cell phone. They will wish they never got out of bed. I will then own them for chewing up my minutes.
link
I thought I would add a bit more to this:
http://www.snopes.com/politics/business/cell411.asp
Cheers all :cheers:
Cheers all  :flag:
Doh!!! I usually check this kinda stuff out before blindly believing it ... got me this time though! At least there's no harm in believing it. Well, other than getting riled up and p1ssed off over something that may never happen. Thanks for the linky, rcj_houston. :cheers:
judging from the snopes article, thatr means that =any day the companycould change their mind and release the numbers. best to "do not call" your # now just in case.
link
Thanks! I just registered my number. :ughdance:
I have an easy fix...Cancel the cellphone. I did without one for 95% of my life, it won't hurt me!
I don't watch TV anymore because of uncontrolled ad's, ditched dish (not their fault, but too bad!), removed my broadcast antenna from my truck.
...And living happily with the boards, XM & DVD's. Not enough ad's to bother with. (Love the spam filter's too)...
Ah, h e double hockey sticks! Someone decided to be a smartass and use my number on all those pop-ups w/ "Free Ipod! Free Mortage Rate Check! Free DVD Player!", all that crap. So I kept getting 'marketers calling my cell phone, until I bitched them all out :ughdance:
    • I only have a few of the ACDelco blue remaining. One or two of the (old, old) ACDelco Professional boxes, and a couple of the newer style GM boxes with the simulcast in Chinese along with English. FWIW they've all been pretty good, regardless of where they are made, and in 20 years I've never had a problem with an e-core filter.   Now I have a couple of the "A" series in my home inventory. They come in a plain white box with the GM hologram sticker and model information. Have not installed one yet, want to use up my oldest inventory first.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
