Bad bearing in ac pump?
fireball
Recently I've noticed a noise like a dry bearing coming from the engine compartment and started tracing it down.First I thought it was the alternator,no, next the idler pully bearing,no,and next the belt tensioner bearing,it was a bit dry but still not the cause.I was driving the other day and had the heater selector on floor instead of mix and the noise was gone so I put the selector on defrost and it came back so it must be in the ac pump right?Is it a big job to replace the bearings in it?Thanks.
If it is the compressor, it can be a bear to change bearings. There are two "sets" of them though. One set allowed the compressor to free wheel the pulley when A.C is not in use but the other set is internal and require a compressor removal and rebuild with the freon being removed and replaced in the process. I would suggest you replace the unit and not bother with repairing it because the noise could also be coming for internal swash plate too that the pistons ride on. Even if it is just the bearings it is still a sign that they rest is not far behind so hence the complete replacement. Systems that are not properly charged to and fail early because the charge lubes and cools the compressor internal parts. When you change a compressor you should always replace the receiver/dryer too.
You failed to say what model, year, type of compressor, etc., but generally speaking, compressors on GM vehicles are not internally repairable. You might find aftermarket internal components, but you sure won't get them from GM, so I wouldn't consider overhauling a compressor an option.
The pulley bearing is replaceable on most compressors, and is the only component we'll replace. Otherwise, the complete compressor is replaced. GM doesn't even want us replacing the front seal.
If it's noisy with the compressor OFF, it can only be the pulley bearing (assuming all other rotating components have been eliminated). If it's only noisy with the compressor ON, then it's most likely an internal compressor problem. Time for a new one.
I have seen them in the aftermarket (parts) and for some models of compressors you can get rebuilt or brand new Delco unit from Advanced Auto and a lot cheap than a dealer too. They do not current all of them new but they did for a buddies van over a year ago and he paid under 200 for it too and it was NIB. (New In Box)
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,236 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
