Cleaning black molding parts???
Armor-Dillo TS-1
It might be a little hard to find though.
GM has a bulletin for us to use it on the Avalance's cladding and bed covers,So you might want to check with one of your local GM dealers to see if they got any.
(There's a post on this going in the full size - light duty forum with lots of good info)
I used Mother's Back-to-Black with good results.
I second the Mother's Back to Black!
I used it last weekend and the one spot I skipped (by the license plate) looks a whole lot worse.
About the only thing I wish I would have done is to mask all the paint by the fender flares. I had just waxed the truck and got a little of the Back to Black on the paint. No biggie, but a little more time and some tape would have been warranted. The stuff isn't black. It's a milky clear liquid. Use it on the lower air dam too. It brings the gray back to life too.
It does have an odor, so I would not suggest using it on the interior, but outside, it does the job very well.
Thanks for the replies... but the white I am talking about is from me not being careful when I waxed the truck... not fade from the sun... I think I need some sort of cleaner, not a restorer....
I third Mother's Back To Black. Finally got around this weekend to use it to take off the dried wax from about a month ago on my door handles and tailgate handle. Did a great job removing the wax and making all the black trim look new again.
Negative. . .I had the exact same thing-white wax residue on the black plastic. Mother's erased it like a dry erase board.
Mr Clean Magic Eraser!
It works great for jobs like this! If it doesn't work, try some Simple Green or any all purpose cleaner diluted to about 50/50 or 60/40, use a mild bristle brush to scrub the plastic, it will look good as new!
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
