Looking for feedback from anyone who has purchased or seen the LED tail lights upgrade? I have seen them on ebay in a chrome housing or in red. I think both look pretty cool and would love to see an 'installed' picture.
Ebay Item Link
Anyone got em? or have seen them that could throw two cents in?
thanks!
Ebay Item Link
thanks!
I have the smoked version of those LED tails; style-wise, they're okay IMHO. I got them because I got a killer deal on them, plus I wanted LED tails that could light up faster than filament bulb tails (confirmed via A-B-testing on my truck; the difference is negligible but noticeable) The clear lens/chrome background combo may be a bit ricey for some folks; and unless the maker of those tails have changed the design, IIRC the red ones are really clear lenses w/ the chrome backing being red in color--IOW the red one does not utilize a red lens. You may find that you may need to resolder the LED bulb connections; I have personally found that the solder job on these units leaves a bit to be desired...having found this out after noticing that a few LEDs not lighting up. If you do decide to get the Eurostar LED tails, make sure they come with the adapters so that your cruise control will still work; the factory GM cruise control on our NBS trucks/SUVs works in part by detecting resistance from the filament taillight bulb. The LEDs in the Eurostars apparently don't put out enough resistance for the CC to detect; hence the addtion of adapters (essentially, a module containing a resistor or two) to correct this deficiency. I was one of the first folks (if not the first--when I mentioned this to the distributor, they claimed that it was the first time they had even heard of the problem) who discovered the CC issue...hence my somewhat-detailed knowledge on this matter.
toneman,
Thanks for the response and info. I appreciate it! Do you have any installed pictures? Also, how do the parking lights and brake lights work with the three rows of LED's. I think I read that they are dual stage LED's does that mean they have the 'double-filament' style of the old bulbs or does one line of the LED's light up for parking and another set for turnsignal/brake?
Thanks again!
great info!
j
The pictures on eBay look awesome! jseltmann, if you get them you have to post pictures!!!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
