Changed Rear Differential Fluid
It was pretty easy w/the instructions in these forums and Mountaineer Tom's pictures and part #'s.  I even decided to paint the cover dark blue to match the truck before I reinstalled it.  The hardest part was getting off the old gasket.  Had to use a little brake cleaner and pocket knife action to get it good and clean.  I took 2 quarts and one squirt out of the third bottle of 75-90w mobil1.  The allen wrench tip really helped.  I torqued everything to ~25lbs.  Is that right?
Just thought I would post something in here.  GM-TC has been dead the last couple of weeks..
(Edited by chane at 12:41 pm on Aug. 16, 2001)
No sealent, just a new GM 10 hole gasket.  I torgued them between 25-30lbs.  Probably closer to 25lbs because I didn't want to overtighten them..
(Edited by chane at 1:19 pm on Aug. 16, 2001)
i used some stuff my dad gave me.  Worked pretty good he suggested it since hes a mechanic.
I did mine exactly 30
So far no leaks (knock on wood)
Ryan
Thanks for the reference chane.  Post a pic of your painted cover when you get one.
I used a small amount of gasket sealant.  No leaks so far.
I also used Toms advice on the allen wrench.......worked like a charm. I used some hi-temp sealent on my gasket, I figured since the old one had to be scraped off that it must have had some from the factory.
BTW Chane did you have any shavings on the magnet?
Ryan,
Do you know that guy in the link you posted?  If so, do you know if he makes those under seat storage box by hand?  Wonder if he could make one that covers the passenger side floor and the hump only?  Also, do you know if he painted it, or is that a carpet type covering?
I've been thinking about building my own type of storage box with a lockable lid, but have never got around to starting it.
TOM
yes i know the guy.
He made one and has the drawings i think he was trying to get a patent.  Dont know much detail about it though.
Let me know if you want his email ok
Ryan
gm lube
? a quart
used 2 and about 1/4 of the third
you can use mobil 1 75W-90 synthetic but if you ever have any trouble there could be a possibility of gm not covering it.
I bought the gasket at the chevy dealer for like ? i think.
i dont have the p/n on hand
if its not posted before i get home tonight ill post then
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
