1995 SIERRA IGNITION SWITCH
My 1995 4x4 SIERRA XC is having some starting problems. I believe that the ignition switch needs to be changed. Is this a do at home job, or do you have to pull the air bag to get to the switch? Any advice or instructions would be appreciated.
Are you having trouble with turning the key? I found that the key to my 92 was worn a little too far so I took one of my spares and had a fresh key cut, problem solved....
--Mike
