Hole in my Transfer Case
I recently purchased an '02 8.1/Allison with 109,000 miles and noticed the hole in the transfer case. The hole is on the lower half of the case instead of the top. Is the hole in this location caused by the pump? What length screw can be used to plug the holewithout causing interference inside the case? I've tried J-B weld 3 times and it hasn't lasted more than a couple of hundred miles.
  • Replies 134
JB Weld is a great product! However, you are battling physics here. Look at the photos I think that I figured how to attach.
The oil pump has four tabs once they start sawing into the case they have A signifigant mechanical advantage.
When you JB weld one spot, all that force is applied to the one repaired location.
The screw thing worrys me, If you could tap all four boss's, and insert hard machine screws.. Maybe, but
It makes the engineer in me sweat!,
Even if you plug the hole, the pump is still free to move a good deal, so look at the photo, there is an
o' ring around the pump pickup tube, mine was totally destroyed from the movement.
If you were to take the rear case off and fill all the wear grooves (JB) + add a "case saver" I think that you
will not have to do it over.
I have not heard any one having only a hole in the lower boss, but I suppose that you just have a case that may be lighter than specs in that location. Remember, just cause its poppin' out there, the other three are diggin in as well.
I'll post more detailed case photos of what your battling later
ttfn ED
Thanks Ed, I was looking for an easy fix, trying to patch
the hole without removing the case. I see now that the problem
is deeper than the case.
I also have an '01 Tahoe. Do you know if this problem affects
the half ton trucks?
1. Newbie
2. Found this site on Feb. 10 2008, Why
3. Oil on driveway sunday afternoon after 200 mile trip home from Orange Beach Al.
4. So far you guys have hit the nail on the head
5. Yesterday after work cleaned up t-case, tightened up bolts, then carefully examined and discovered 2 holes on the lower half of the case.
6. cleaned, sanded, applied a temporary patch till I can find out how to fix the problem.
7. HELP!!!!
8. Back to #1, since I'm now a logged on member where do I find this topic in the gm-truck.com site, found the thread in a google search and saved to favorties, but haven't been able to find it through the site home page.
9. Thanks for all the great info
BA
ttfn ED
Could you please explain what it is that you are showing in the picture. I think I can tell what is going on, but not sure. Also, for those that simply plug the outside of the case, what happens to the clip that breaks on the inside? Is it rattling around, possibly getting caught in the works? What about the metal shavings that must be caused by the wear, what happens to them?
I am admittedly a bit surprised and worried upon reading through this thread, as I have a feeling it is a matter of time before my 04 has this problem. I have about 60K on the truck and the warranty will expire in a another 40k miles, so hopefully if it happens it does it while I'm still covered.
Hey guys,
Yesterday went looking, a good friend @ the local parts store said he couldn't get parts choices junkyard or local dealership.
Went to dealership discussed with several people, this is what I came away with
1. back half of case, clip, oil, gasket sealer $500, labor $700-800 total $1200-1500
2 new t-case $1500 labor $500 total $2000
3. new case $1500 install myself total $1500
4. Not sure if I want to break apart but #1 w/o labor $500 but what will I get into?
Any Feed back?
BTW: 2001 2500hd 6.6 duramax/allison 115,000
BA
ttfn ED
Sorry for the delay in reply, I am taking some photos of a bad case and the oil pump and exactly what the problems are, Including that (anti rattle) Chev calls it an (oil pump wear sleeve)clip that doesn't do anything except break off.
I took photos last night but they came out terrible, will retake tonight and write up a proper document and post it.
I have to drive to Seattle tonight, so it might be a day or so.
The photos will show how the pump (after the clip breaks) eats into the case and exactly where it does. BTW
I checked mine it did eat the bottom boss, but there was a pin hole in the top as well. You really don't know when that clip breaks since the magnet is clear inside the case at the spilt and the only possiblity is fishing it out with a stronger magnet
then the one in the case. Mine ground the clip to dust. I suggest that when the case is drained to strain the oil through a pair of nylons and at the first sign of any signifigant amount of magnesium grit, cry foul! because there should be none
in the oil at all ever if everything is working properly. Magnesium is from the case or the mode shift fork, Steel would be from the clip or gears.
I'll post more later (sorry but work comes first)
Hey guys,
Any Feed back?
BA
If you are as I said proficent with a set of snap ring pliers and seal drivers (bearing pullers help) you can do this in an evening on a solid table. Its not bad, If you need I have the exploded diagrams.
I prefer doing these myself because I know exactly what I have replaced and what condition its in.
I bought every bearing, chain, seal and the rear case for about $450 so I have basically a new unit.
My unit also needed the mode fork, and a couple of gears so I went about $650 to complete the repair.
Make sure you get the case saver!!!!!!
What model of Transfercase are we talking about here? If memory serves right didn't chevy have two different t-cases available from 04 on down. I was thinking that they still used the older version yet... Anyway makes me glad I still run the old cast iron 205 with geardrive...
  • 4 weeks later...
Gents--
The solution to this problem comes from Eric at Merchant Automotive, www.merchant-automotive.com
I have his kit for the transfer case pump rub problem and will be installing it this week.
Check his website and get one installed before you blow yours apart from dry running.
Until the case is redesigned to prevent this type of component movement within the case, this is the only way to improve the situation.
Good luck.
Best,
Brant
  • 2 months later...
I have a 99 Cadillac Escalade (5.7L), and I noticed the "pin holes" in my case as well, thought it was a casting fault... tried JB Weld, didn't hold long.. went to another type (not sure offhand the name).. seemed to hold for a couple months... then I noticed the oil on the floor again 2 days ago. The problem started at about 110,000... now I am at 116,500. I was about to kick it to the curb when I found this thread... might have some new found hope.
So it doesn't seem to be on just HD models.
    • Can someone tell me where the video processing module is in a 2023 Silverado? I'm getting conflicting results that it's in the front passenger area or the rear passenger area behind the seat.
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
