More power for a 5.7 TBI
I have a 94 2500 4wheel drive Sierra 3/4 ton pick up with almost 200,000 miles on it. I just rebulit the 5 speed manual transmission and transfer case. I want to up grade the motor with more power.
I don't want to get into the problems of swaping up to a big block. The emphisis needs to be increasing the low and midrange powerband as I haul a camper and pull a boat. A wild cam will push the powerband too high to be of use. What are some good options? A stroker 383? A more conservative cam, head, and header setup? Super or turbo charging? If anyone has experience getting more low and midrange pop out of a 5.7 TBI I would like to hear from you.
Thanks :banghead:
.....cam, head, and header setup?
Thanks :banghead:
Yes. You can buy a cam specifically for low-end torque. Heads and headers would be needed if you go this route.
While most forced induction systems don't start making boost until at least 2000 RPM's, they're a BIG help in towing too. I wouldn't put them on a 200k mile motor though.
Right, I wasn't thinking about changing the current motor with 200,00 miles on it. It is the rebuild or new crate motor that would get the upgrades.
Thanks
