I recently installed a body lift on my 2002 Silverado and I am not entirely satisfied with the way the tow hooks are reinstalled. Is there an aftermarket front piece that will get me a better appearance?
Thanks,
Jeff :yingyang:
Congrats on the body lift.  :D   I just installed one last weekend too.  From looking at your site, it looks like you may have did the same as me as far as trimming the lower opening so the hooks will still fit.  Airdam after body lift  I didn't think it looked too bad, although I would have liked to installed them without having to trim anything.  One guy at FSC swapped the drivers side and passengers side hooks, flipped them over, and then drilled out the hole in the frame a little bit so the bottom bolt could be installed.  I tried swapping and flipping them, but that bottom hole didn't line up, and I wasn't sure about drilling the hole out in the frame.  The guy that drilled out the hole, said it didn't take much and he hasn't had any problems.  :)
Check out Victory Red's webpage.  Victory Red's - 2001 Silverado LS Z71  He has the PIAA airdam installed, without a body lift though.  He has some good pics that may give you an idea of how much room is available.   :)
