I have found bigger tanks for 2500HD and 3500 trucks that mount in the stock location under the bed but not for a regular 1/2 ton. Is there any available for the new body trucks?
Because of emissions on #1500 a larger tank isnt feasable. If you install a larger tank you will cause evap. code because the PCM isnt calibrated for the larger tank. Gas weighs about 6.5lb a gallon and carrying more will hurt your fuel economy.
