Cheap Lowering Idea.
Cutting torch+original spring=lowered truck...
I cut a few rungs, off the coils of my 88 Blazer back in my wilder days, put a set of blocks in the rear and presto. Lowered ride.
  • 1 month later...
Spring compressors do not work. I helped install some on a 99 Z28 and they broke, all three times. Cutting with a torch ruins the springs, so I would go with one of the cheaper lowering packages offered. Just my two cents.
  • 3 weeks later...
If you're gonna cut your springs which I don't reccommend AT ALL, use a sawzall to do the least damage to them. Heating up them up ruins the spring rate even more than just cutting them.
No worries there, I would never try to cut the springs just to save some cash.
Taking a hacksaw is the safest and most irritatingly slow way to make a spring ride lower. In some cases, it works too!
For example, the 460# springs that aftermarket suppliers sell for 68-82 Corvettes are simply the 550# springs with a few coils added. Hacking one up will give you a 550# spring as well as about a 2" drop.
The problem is, you really don't know what you'll end up with when you cut springs. It's a lot of effort to do, if you cut too much you're SOL, and if you cut too little you just have to do it again. Never cut more than a 1/4 coil at a time, unless you know what you're going to get.
All that said - a lowering kit that gives you a known drop is probably best. Lowering spindles are better than lowering springs in that most of the ride is preserved - any lowering through modifying/replacing the spring is going to result in a stiffer ride.
-Steve
The spring compressors actually damage the springs, stay away from those. I used the shackle and hanger/control arm drop on both my '94 ECSB, and my '96 ECSB, they both rode and drove very nicely.
Pat
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
