how to turn off change oil lite
i changed the oil first thing when i got my 2000 sierra recently. then a week later the change oil lite came on. my father in law says theres some sequence of stuff to do to turn the lite off. anyone know it?
Turn ignition to "Run" (engine not running)
Press gas pedal 3 times to floor within 5 seconds
"change engine oil" light should blink several times when reset.
  • 2 years later...
bumping an old thread... :dunno:
I've tried every method of resetting the oil light that is mentioned on here, gas pedal 3 times then off, gad pedal 5 times then off, gas pedal then on etc.
But I still can't get the damn light to reset.
It will still flash 5 times when I start the truck no matter what I do, is this normal?
or am I not resetting it properly
I turn key on, hit gas pedal 3 times wait for light to flash then turn off.
Don
2002 GMC Sierra Owner's Manual
Page 385 (6-18)...
To reset the CHANGE ENGINE OIL message do the following:
1. Turn the ignition key to RUN with the engine off (make sure all doors are closed - read that on another forum).
2. Fully press and release the accelerator pedal three times within five seconds.
If the CHANGE ENGINE OIL message flashes for five seconds, the system is reset.
Or See Post # 9 on this thread.
If you did the procedure wrong nothing would happen. The 5 flashes means it is reset.
