GM trucks kick BUTT
Not bad at all. Not surprising either, considering the amount of upgrading GM is constantly doing to its diesel engine/drivetrain.
I will have to forard this link to all my Ford / Dodge loving buddies.
Interesting that they called the GM's interior out of the 90's, yet the seats were rated best and most comfy. IMHO, both Ford and Dodge interiors are fisher-price-like crappy and just plain old ugly.
You think GM has an advantage now...just wait until the new models roll out. I've driven the new Tahoe and it's fantastic. Just waiting for 0% financing and the wife will be driving a new Burb.
Hey now, FP was like the Cadillac of toys when I was growing up, ha. :driving:
The Chevy kicked butt in the towing category too, but.....
Somebody explain this:tow test specs
They had to handicap the already heavier Ford by adding 3700lbs of cinder blocks to the bed in addition to the trailer. They only put 2440lbs in the Chevy and none in the Dodge???? Then they hooked up 8600lb trailers to each and did the test.
Edmunds call this "leveling the playing field" due to the Ford having a higher GCWR. Are they afraid to just simply attach equal weight trailers to each truck and let 'em pull? :driving:
I realize I run the risk of sounding like a sore loser but even a die-hard GM or Dodge fan has to admit that's a little bit ummm...fishy. Seems like they would get a better indication of relative engine performance by just letting the trucks pull the same weight with empty beds or even rigging them so they all had the same gross combined weight.
The Ford was moving about 21,000lbs. The Chevy only about 18,500lbs. All this part of that otherwise good test proved was that the Chevy is faster than the Ford as long as the Chevy's moving about 2500lbs less weight.
And I have a feeling the Durmax would be quicker under equal circumstances anyways, which really makes you wonder about Edmunds (note the big flashing Chevy advertisemnt off to the side of the article). :crackup:
Yeah that is about stupid. Chevy ads on TV and radio are always telling you to goto Edmunds.com so maybe they are to much biased.
On a side note. DANG! I thought my truck was heavy.
Vernon
I found the statement that the Ford was bouncing off the bumpstops kind of interesting, too. I think they should have put the extra weight in the trailer, not the bed.
I do agree that they should have tested the trucks without the ballast.
I also think they should have tested them at their maximum combined weight ratings.
BTW, I was reading the Specifications and Performance page and Edmunds got a little confused there. They gave the Ford a twin I beam front axle and 245/75/17 front tires to go with the 215/85/16 rear tires. Plus they are now "Rudded" Trail tires instead of Rugged. I think someone needs a new editor.
The Chevy is the only one with 16" wheels. The other two have 17" wheels.
They gave the Ford a twin I beam front axle and 245/75/17 front tires to go with the 215/85/16 rear tires.  I think someone needs a new editor.
LOL, either that or they considered the spare to be the "rear" tire. What a bunch of dump.
Vernon
Towing capability has a lot to do with axle ratio as well.
If I remember right the Dodge and GM had 3.73 and Ford had like 4.60. So again they are not comparing apples to apples.
    • No, not yet. Hoping I'll have something a little more definitive in the next day or 2. They seemed to be very confident they can order it. I do have some understanding of the whole allocations and restraints stuff so we'll see.   I think this is what I'm looking for.   3000 ORDER ACCEPTED BY PRODUCTION CONTROL
    • Then you haven't read your book. It also says check every 400 miles.   If you need to add multiple quarts in that distance then reading the stick isn't the issue. Put the two together and it will make sense. Read it all.
    • Following up on my topic, I put an O2 sensor in it which seems to have got rid of all the b2s1 codes (I ended up having multiple codes). Next I’ll try to figure out the P0011 but I might focus on exhaust manifolds first, they’re getting pretty rusty. I’m hoping this thread will help someone in the future.
    • I’m going off the instructions.
    • My expectations are a bit higher.    No faded paint or dry rotted plastic/rubber. I use a dressing and a ceramic sealant. No hazy headlights.  No door dings. Small dent in the front bumper. All rock chips repaired. No brush scratches. No windshield chips. No fender benders. Limit damage due to a proactive plan the included ceramics and PPF and prompt attention to any exterior issue. NO RUST. Stays out of the salt and had the rear wheel wells Line-X coated as well as the bed which has a bed rubber and has been under cover since before I bought it. Washed and detailed regularly. Rex chewed up the tow button, got whacked and the button replaced the same week. He's leaned his lesson. If I can train a dog the kids are easier.    All suspension is original save the King Shocks I installed very early on. 50 years ago dad told me a good shock will keep the screws in the dash tight and the front end mint. He was right. Everything within new spec yet, tight and aligned well several times. Coolant system is OEM save the modifications I made early on. Not a single leak anywhere on this machine. (Did repair an intake leak on #4 during the HPFP replacement.) The injectors I replaced didn't need to be. They checked out great. One of those, while I'm in there with the manifold off and the fuel rail apart things.  Not a stain or abrasion one to the upholstery. Have kept is covered since new. Never had a carpet, it's a work truck but the carpet squared I laid on the floor have keep the factory rubber liner MINT. Ceramic wind tint helps preserve the interior.    Original BRAKES with 60%+ left of the pads and rotors mic excellent. We just did a full preventative brake service. Disassembly, clean inspect including measurements, lube, Dot 4 power flush including ABS system.    OEM battery. OEM vacuum pump. In fact the only things not OEM are a pinion seal the high side pump and injectors and a small plastic shield around the starter. All hoses/belts etc.. are still in service and doing well. Original tires lasted 125K and had I known some additional details would have made it to 150K with legal tread. (Date out is six years, not 5 and Continental says they are good for 10 so I pulled the trigger to early)   I never let my children or grandchildren run the show. Feet on the floor and hands in your lap. Dog gets a pass.    A truck is a machine the gives you back whatever your willing to put into it. Same as a computer or a butter knife. I use a shovel but I scrap it, hose it off and oil it when I'm done with it. My original spade I've had 60 years.      Set the bar higher...you spend less money. No, before you ask, I have spent a fraction of the cost of a new truck in my entire maintenance program including disposables, filters/fluids etc.
