RadoSilver Posted August 9, 2002 Share Posted August 9, 2002 The next project I plan to do will be to sound dampen my truck. I had a few of questions. 1. What tools will I need? 2. Will I have to remove all seats at once to pull up the carpet. 3. Will 1 layer of sheets be enough to reduce noise? Thanks-JD Link to comment Share on other sites More sharing options...
rrsob Posted August 9, 2002 Share Posted August 9, 2002 I don't know how it matches up against the "sheet" stuff like Dynomat, but I read an article in Four Wheeler mag. about a new paint on stuff. They gave the web address but I don't have the mag. on me at the time. I do know it was $40. a gallon and much easier to apply than the mat. I can get you the web address if your interested though. I've never used either but I like the idea of something that can be brushed or sprayed on. I hope this helps. ??? Link to comment Share on other sites More sharing options...
chevy4x4trucks Posted August 9, 2002 Share Posted August 9, 2002 2. Will I have to remove all seats at once to pull up the carpet. I know for a fact you'll have to do this, so give yourself a half day at least to tackle this project. I've got some pics on my site of the tools required and how to remove the seats/carpet. I know Jason Pendlum has removed his stuff and put in some dynomat, so he should be able to shed more light on this situation. Link to comment Share on other sites More sharing options...
Big Bert Posted August 9, 2002 Share Posted August 9, 2002 I used two products when I did mine. I used e-deadE-dead and peal and seal that you can get at your local Lowes. I was told that both are very similar to the Dynomat. I liked the peal and seal better for several reasons one it had a very sticky back and two I could go get it myself and three it was cheaper then the rest of the stuff out there. I applied it to my entire floor and the back wall of my ext cab. I had to remove all of my seats and center console then my carpet and pad. I put on two layers one of the e-dead and then a second of the peal and seal. I used a small roller so I could get the stuff in all the corners and down as good as possible. I think if I was doing it again I would apply a third layer. I had allready done my front doors when I installed my front speakers. I still have to do my back door and opposit side wall of my ext cab and maybe my roof. I notice some difference in noise level but not as much as I was expecting or hoping for but it did help. Some of this maybe because I still have the back side walls to do yet. I hope this helps some. Link to comment Share on other sites More sharing options...
