What sub for this amp?
Ragtopman
I have decided go with a new amp for my truck rather than recycle old stuff. I picked a 5-channel Phoenix Gold amp and need to pick up a new sub for it. The amp is rate as follows:
Subwoofer Channel Max Power Output: 250Wx1 @ 4 ohm / 400Wx1 @ 2 ohm
Subwoofer Channel Continuous Power Output: 150Wx1 @ 4 ohm / 250Wx1 @ 2 ohm
What would be a good sub choice to match to this power output?
Where should my rms be, and how does that compute with a dual voice coil sub? I would like to run just one sub for space reasons.
Heres the rest of the system: front door speakers Rockford 6.5's 75w rms and rear door Infitity Kappas 4x6 60watts rms the head unit is a Pioneer 18w rms x 4 with 3 preout for the amps
  • 1 month later...
My personal belief is that you should always try to get the most out of your amplifier. Being that with amplifiers you are essentially paying for wattage more than anything, there is no sense paying for wattage that you aren't going to use.
In this case, assuming that the amp is 2 ohm stable, I would recommend finding a sub that has dual 4 ohm voice coils, and is rated between 250-300 watts RMS. The reason for the dual 4 ohm is it can be wired to present a 2 ohm load, thus using the amp to it's potential. Another option would be to use two 4 ohm single voice subs, which can also be wired for a 2 ohm load.
And as far as particular subs go, I am not brand biased at all. Just make sure you do your research before you buy, and try to stick to a mainstream company (Alpine, Kicker, Clarion, Rockford, Infinity, ect). Other things to consider will be mounting depth and recommended enclosure volume, as you do not want to buy something that will not fit in the spot you want it to.
I agree with Nova, getting yourself to a 2 ohm load for that amp is your best plan of attack. Whether that is 2 single 4 ohm subs or a single sub that is dual voice coil 4 ohms each is dependent upon what you want to do with your enclosure and how much space you want to give up.
For the money the Elemental designs stuff is decent , I personally recommend the Infinity Perfect subs, or Image Dynamics IDQ or IDmax. Check out the tcsounds.com webiste as well as there is a great sale going on there for very well built subs. Old JL w6 models are tough to beat as well.
G'luck
Fej
    • Good thing my wife doesn't frequent my automotive forums, she might get the idea of strapping me to a handtruck and leaving me curbside for the pickers day before garbage pickup!
    • Okay boys and girls I put a bottle of this in Dizzy the oil burning guineapig after a tank between the coil and plug service of the #3 hole and near the end of the first R&P 5W30 attempt. As a note I did a two R&P oil changes back in October of 2025 with little effect. Granted they were 1K mile a shot oil changes so.... Then followed by fourteen  1K mile changes of Mobil 1 Euro 5W30 FS. Also ineffective.    Anyone who has followed the adventures of Dizzy may remember that to put the oil on the full mark of the published nominal 5 quart change I withhold about a cup of oil. That over the last 50K miles the P0420 light has been a frequent flyer, sometimes three of four a day. And that even on 93 octane fuel she registers some KR even in moderate conditions on favorable days on slight inclines. Lastly when giving her a kick in the pants, something done about once a week, she looks like a diesel with the pump turned up. 😬   After one bottle and over the last 500 miles of a 3K mile OCI, of the first oil change I dropped the nastiest looking oil ever in her history. That's saying something as  you will recall I have used AutoRx, HP EC30/40 and a few other harsh solvents in her before including the GM top soak twice. This was syrup. Black stinky, inky syrup but the filter wasn't all that bad.    On the second fill I had to use the entire 5 quarts to reach the full mark. That was unexpected! The ignition KR is completely gone! Even at 99% engine load. MAP is much lower. Level road is now 9.8 instead of 12.5. Fuel economy is remarkably higher and for the first time since her earliest days she will spin to 6500, more than a thousand higher with out laying down dead. Yes, the coil and plug had something to do with that but remember the first 2500 miles after that repair on the first change it was same ole same ole Dizzy. Seems we have top rings that are somewhat functional again. P0420 code only comes on now if run in town for more than an hour of stop and go. On the open road it goes weeks without a incident. Perhaps it is cleaning the cat on the pass through?  Fuel Trims have improved as well. Nothing not to like.    To early to say about oil economy but the changes to date in the operational aspect is remarkable. I can't think of a worse case than Dizzy.... It's already paid for itself in a few tanks of fuel with the mpg improvement.    @OnTheReel, I'd say if the Jeep didn't respond perhaps there wasn't an issue to respond to.    I've run the Red Line SI-1, AMSOIL fuel cleaner, GUMOUT and Techron all in this SUV without any such results. Color me impressed. I'll be running out my supplies of the list mentioned and moving on to the Valvoline R&P Fuel System Cleaner.
    • Hey Chuck !!Thanks for the all the info I'm an old fart and I have everything I need for the oil change at home,minus flexibility .... and I’ve been doing my own oil changes for 40 years. I just didn’t want to end up without a crush washer or with the wrong one in my stash and have to walk to the auto parts store, lol. I climbed under the truck to check the location, and man, it’s going to be the easiest oil change and filter swap in the last 40 years—right up there with my 2014 Mitsubishi Outlander 2.4. No mess, nothing to drip on—just perfect. I’ve got one more free oil change to use, and then that’s it with the dealership!
    • I think this subforum was created for the new generation pickup trucks (2027-) with the 3.0 but I don't think it's a big deal either way. There are probably 2027 model-year specific changes for the SUV's too.   I was just curious if you had issues with your 2025 3.0. I'm still under 10k miles on mine and fingers crossed I don't have thrust bearing issues. I'm guessing not, since you're willing to buy another one! It's a good engine minus one or two manufacturing whoopsies.
    • Wife has enough metal in her she hides from the scrapper.
