OEM wheels
rado king
I have a 04 Silverado and when I bought it it came with non factory wheels. Im wanting to put factory OEM wheels back on and I know that 99-06 Silverado 16" 6 lugs will work. The question I have is will 16" 6 lugs from like a 03 Tahoe also fit on my truck.
The best thing you can do is measure the width of your bolt pattern. which for your vehicle it should be 6 lug on 5.5... But you got to watch out because Chevy started using 17" rims and tires will cost more for a bigger rim... Hope this helped!
They started using 17" wheels in '05, I think, to clear the larger front discs on the 1500. If you have rear disks, the 16s will work for you, if you have rear drums, and I don't think you do, you'll have to use 17s.
Lou
  • 2 months later...
