hey boys
howdy! my name is britt and i drive a 1982 gmc seirra with a built corvette motor,5.7 or 350 how ever you want to put it. im from xenia,ohio and wanted to make myself known. im a autobody tech and love to wrench on anything in front of me. i know alot about body work and a smidgin' about mechanics. im a country girl and also have a 500cc scrambler 4wheeler. i would love any imput on my truck.keep in mind it has a bigger cam,bigger injectors, its bored over to 355,its ported out,has a chip,aftermarket intake,and a couple other things blah blah blah.oh yeah,it has a 350 turbo tranny. any q's? id be glad to answer!
love lots!,
britt
Kinda tough to comment on a built truck with no pics !!
Ya ever been to the "Rumble On the Ridge" off-road ride in Adena, Ohio?
Welcome :)
i dont have any pics,but trust me the truck aint that sexy.its primer. with some rust,lol. its a reg cab long bed,2wd.im sure you can picture it. it will be worked on this spring and summer,but as of right now,the motor is the only thing done.
I love it when a woman knows more about trucks than I do.
:cheers::devil::confused:
Have you ran it at the track there yet?
not yet, when i got it,it wouldnt run and i had to replace the brake lines. by the time i got it tuned the way i wanted it,the track was closed for the year and it aint opened back up yet. so i cant tell ya what it runs. but i will let ya know when i do run it.
Britt, first of all, welcome to GM-TC. It's always nice to see the female side interested in vehicles like the male side is.
That said, I am going to edit your user info to remove the link for Your Website. I'm sorry but something like that is not appropriate for this site and will not be tolerated. All I ask is that you not put anything else like that on this site, be it in the forums, your profile, signature, avatar, or anywhere else you can think of.
Thank you very much and enjoy your stay.
-Frank
edit- On second thought, I'm going to give you the option of removing it yourself. People should know better than to put certain things out in the open like that and the URL of that site is all I needed to see to know that it has no place here. Please remove it if you wish to stay.
-F
-Frank
-F
not shure what your talking about, im confused? i didnt mean anything up offenencive. kinda hurt
-Frank
-F
He's talking about your racist username on Myspace.
He's talking about your Myspace page, more specifically, your rather explicit username there.
We try to keep this a family friendly, and work-safe site. So our rule is basically nothing above PG-13 content.
There's no need to feel hurt, I'm willing to chalk it up to an honest mistake, and I'm sure Frank is too. :confused:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
