Too Much?
I pick up my new fifth wheel on Monday the 18th. The "empty" pin weight of the trailer is 1365lbs. Is that too heavy and if not, How much room do I have to play?
Firepoggy,
You need to do the math on this. Go weigh your truck with a full tank of fuel and you in the driver's seat. Most trucks weigh more than the "curb weight" published my the mfr, due to the addition of options, etc. Subtract that actual weight from your GVWR and that will tell you how much you can carry in the truck. Subtract any additional passengers, tools, etc, not included in your truck scale weight and that will give you the max amount your 5er pin can weigh.
Also bear in mind that "dry" weights don't inlcude propane, freah water, and everything that you pack in the trailer. For example, items you put in the front basement by the landing gear will add more to the pin that items placed further back, and weight that you add behind the 5er axle will actually subtract from the pin weight. When the trailer is loaded and ready to go, you may have added another 300-500 lbs to the pin, depending on what you loaded and where you loaded it. Again, the only way to tell is to weigh.
If you a 2500HD with 9200 GVWR, you are likely going to be fine with that weight, but actual weights will tell you what you;ve got instead of guess-timating.
You can get more specific info from folks that tow 5ers with your truck over at the RV.net Towing Forum.
You really need to find a scale and weigh the rig. First do the truck and trailer axle by axle, then go unhitch and do the truck. Most truck stop scales will do this, just tell them that you are a non commercial vehicle. When you get your results you should be able to determine the effects of the 5th wheel on your truck. Compare the loaded rear axle with the GAWR to insure that you are within spec, and then make sure that your GVWR and CGWR are all within spec. I would suggest that when you weigh the rig you should have a full tank of gas and water along with camping gear. For more opinions visit such sites as IRV2.com and RV.net
Guys... He's looking at 1365# empty! His truck could carry dbl that in it's bed alone! If the king pin weight is that light, I would guess the trailer weight to be under 10K lbs GVW (26-28 ft). He has more than enough truck... however depending on the motor, there could be more Q's and A's
Got the trailer and so far no problems. The motor howls a bit going up hill but the truck seems to be doing fine. The pin weight dropped the truck an inch or two. I also asked this same question at rv.net but was only receivng answeres from Ford and Dodge owners, that is why I posted here. Thanks for the help.
Looks good, truck is sitting nice and level so you should be fine. Good luck with the new 5er!! You have the 6.0L in your truck?
Nice looking setup! I'm sure you will enjoy it.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
    • I'll bet your truck lost the bearings on a roller on 1 of the lifters, and now is wiping out a cam lobe.
