Strange Russeling Noise
2000 gmc Sierra 5.3 373 gears. I have never heard any noise like this in any vehicle. When towing the boat on hi way for half hour or more, there is a strange russeling noise, like dry leaves or newspaper being crumpled. Now, the noise cannot be heard while driving above 60 kms hour, but if I slow down when I get to a city or town, the noise starts up just while accelerating. It does not sound like it is coming from the engine. You can hear it coming from just below the cup holders and ashtray area of the truck. When truck shifts from 1st to 2nd, the noise quits during the shift and starts up again until you hit speeds of over 60km. then seems to disappear. It almost sounds like it is coming from firewall area in center of truck. This only happens when towing. I tow in 3rd and use tow haul. This noise is very noticeable. Please let me know if anyone has ever encountered this problem. Thanks
Does the sound speed up the faster you go or is it constant no matter what speed you at.
Thanks for the reply. No, the volume of the noise nor the speed increases. Sounds like someone sitting under the ashtray, crumpling dry leaves.
sounds to me like detonation (spark knock...pinging)
Try the next step higher octane gas next time you tow and see if it still does it
Do any of the heater core hoses run in that area? I've heard sounds kinda like that from air bubbles getting pushed through the cooling lines before. Just a thought/guess.
I am just wondering if there are any trani lines that run close to the firewall, as the noise quits momentarily when truck shifts from first to second, then I can hear it again until I get just past the 60km range. If I take off the tow haul for a minute, noise seems a bit quieter. Seems to be transmission shifting that regulates the noise. It is not a tapping noise or anything even close to a mechanical noise, but more like russeling leaves. Really weird. I guess I won't worry about it as everything seems to be running fine, but if anyone has ever had a similar problem with their truck, I would appreciate hearing from you.
I had air in the heater hoses that come through the firewall that was causing a gurgling that would decrease in intensity when the truck shifted
Air in the lines sounds very close to what this sounds like. I will check a little closer and maybe get someone to stick their head down there while I am driving (even though that might look a bit funny from passer by's).
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
