Tsb On Ebony Seat
I think it is pretty obvious that GM is not going to fix the lint issue, at least not right away. People just need to get over this little pet peeve, and if it bothers them so much, get a nice set of seat covers, which you probably would have done anyways in time, and get on with your lives. I have the lint issue as well, but I do not see it as anything worth wasting time and energy getting upset about. Sometimes life just sucks, get used to it. Even if you had to pay $35,000+ for your truck. Life is not fair. Now go eat worms.
  • Replies 1.4k
I love that the dealers get a free pass in all of this. It's not like I bought it used. They made money selling it to me but bear no responsibility for it? I know if I put something in your house that goes to shit, I'll make it right. Regardless of what the manufacturer does. It's called having integrity.
Its not that were getting a "free pass" danny,We want to fix the problem,GM just won't give us new covers to fix it!
It is not so much as a pet peeve, it is a real PITA to have to use a lint roller at least twice a day on my pants when I go to work. I wear a black Naval uniform, and it looks horrible everytime I step out of the truck. Ang God forbid I need to have a passenger from work in my truck, also in uniform. No, it is not a pet peeve, and no, I will not get used to it. It affects the way I conduct business utilising my new truck.
I walked into the GMC service department from work, and showed the service manager my uniform, and he was shocked and that is how I got them to pay for new seat covers. I chose Katzkin, and GMC is paying for a good part of them equilivent to what new GMC seat covers would cost.
This is a place to talk about concerns with trucks. No one is threatening to fire bomb anyone. I don't think. :lol:
Well....maybe some good news guys....Our GM rep. said new covers "should be" out by October,...Now he didn't say what year :lol: But hey at least its better then no news.
I understand that GM isn't providing a fix. I think most people have figured out the fix themselves, Katzkins. I can tell with all certainty if a manufacturer provides me with faulty materials and takes a year "engineering" a fix I would step up to the plate. If the materials aren't showing, I will replace them with something else on my dime. That isn't a hypothetical, I've done it before and will again. If you want to make money selling something you didn't make, I think you are accepting responsiblity for it. Or at least you should if you do what's right.
It is more than an inconveniance. I have to take clients around in my truck to look at projects. I can't get them to believe that I will keep their house clean during construction if it looks like I haven't taken a vacuum to my truck in a year. I have to spend 20 min vacuuming before every appointment.
I'm going to schedule myself some extra pudding for the horror I face on a daily basis.
I hear ya' danny,I hear ya'! :lol:
Maybe we'll get the new covers soon now,Although I'm not holding my breath. :lol:
Considering that moon visor mistake you are about to make, maybe you'd be better off holding it until... :lol:
Speaking of which...put that and the wheels on already Rich! Whats the holdup!?!?!
The wheels are ON!! :lol:
The sunvisor isn't,I'm waiting for my buddy to call me and tell me its painted.
Considering that moon visor mistake you are about to make, maybe you'd be better off holding it until... :D
:lol::lol:
Well how about some friggin' pictures then? You'd have thought you'd have learned by now! :lol:
OK,OK...I got to get my brothers camera,I don't have one :lol:
    RyGuy43
    RyGuy43
  • Who's Online   1 Member, 0 Anonymous, 568 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
