Tsb On Ebony Seat
i am glad I waited. it was actually my salesmans idea. he said to wait till my warranty is going to run out then get them swapped. its a pain dealing with the lint esp with 2 light colored dogs in my truck alot. I can tell you one thing these original covers are total crap. the bottom where your bum sits is totally worn in the center. there is no pattern just a fuzzy mess. and that with 20k miles. i would be really mad if they weren't going to be swapped out.
  • Replies 1.4k
I have the same problem, and I wear alot of dress clothes so there's no reason the seats should be wearing like that... I guess I'll have to go a step further and contact GM
I just had my seats recovered yesterday. I included some pics. Can someone tell me if these are the new-new covers or are they the old-new covers?
My uncle bought an 09 sierra about 2 weeks ago i like these covers much better than the ones on my 07. is it just me or are the 09 seats firmer too? Anyways he brought it out 2 days after buying it and the outside and headrest still collect lots of lint possibly as bad as the 07 ones. The middle part is fine but the sides and headrest still collect it.
Then he has the old design seat covers.....Most,if not all '09s,had the old style covers.
Hello MSDALE, Are you saying that the pictures above are the old style covers? My truck was made in September of 09 and it has the covers like the ones in the picture above. If so I need to check on replacements.
No,The pictures above ARE the new style seat covers,I've seen very few '09s with the new covers though,however with yours being built so late into the model-year its quite possible you have the new covers.
What they changed on the newest covers was the outer portions/sections,They went from a "velour type" fabric,to a "thread type" fabric. (The first time around they changed the inner portions/sections from velour to a smooth fabric)
Needless to say this has been a nightmare,and quite confusing.
Hi MS3DALE,
The dealer changed my covers last year. Do you think that they can change it again with these new covers? My truck warranty expires on August.
Thank you
Hi MS3DALE,
Thank you
They might,especially if your still having issues with your current ones,all you can do is ask.
I just bought an 09 GMC SLE any my covers look like the ones posted a few posts back. They have the "stitched" center but the sides are still the soft style material. I was told by one of the techs that he believed the covers in mine are the newer ones they were replacing the old ones with. I honestly cannot stand these seats. The outside edge picks up every little thing and the back seat (crew cab) stays covered. The truck has 800 miles on it. I would honestly return it it they still had that policy. Im not a picky person at all, but Im ashamed to let anyone ride in it because it looks filthy. I wanted to file a complaint but dont know the best way to do it. Email or call. I would even go as far as going in halfs with them to put in some leather. Its not like Im just trying to get a deal on leather, I honestly dont even like leather. I would, however, rather have that than some covers like the ones that are on it. No way Im gonna make it with these pieces of s#it.
matt
matt
So the sides still pick up lint, but the centers do not?
OK,I'm going to say this one more time and hopefully it'll help clear up any confusion....There are NEW covers that just came out in the past few months that address the lint issue,The 2010's have the new covers,If you had your covers changed before Jan/Feb of this year chances are you still have the older covers, "GMC MaXx" posted pics of the new covers that address the lint issue.
matt
Yes,Thats the issue he's having,He needs to have the new design covers installed that have the "thread/stitched type" fabric on the sides.
I got you now. Sorry, It was hard for me to make out the material on the above pics. I thought those were like mine but they are not. I actually found a picture of the newer covers on another forum that shows the difference a little better. I am gonna go to my dealer tomorrow and have them order my covers. Thanks a lot for the info.
matt
I went to the dealer on Wednesday to address my lint issue and this TSB and they approved the insallation of the new covers!! Im Excited! They had to order them so prob put them in next week sometime. :rolleyes:
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
