Tsb On Ebony Seat
  • Replies 1.4k
Heres the list of part numbers....
Regular Cab Pickup
Part Number
Description
RPOs
15909157
Restraint, Driver and/or Passenger Front Seat Headrest (2 required)
A95, AZ3
20833414
Cover, Driver and/or Passenger Seat Back Cushion (2 required)
A95, AZ3
20833416
Cover, Driver Seat Cushion
A95, AZ3
20833415
Cover, Passenger Seat Cushion
A95, AZ3
20904119
Armrest, Front Seat
AZ3
20904111
Cushion, Front Seat Center
AZ3
Extended Cab Pickup
Part Number
Description
RPOs
15909157
A95, AZ3
20833414
A95, AZ3
20833416
A95, AZ3
20833415
A95, AZ3
20904119
Armrest, Front Seat
AZ3
20904913
Cover, Rear Seat Cushion-LH
A68
20904917
Cover, Rear Seat Cushion-RH
A68
20904111
AZ3
20904905
Cover, Rear Seat Back Cushion-LH
A68
20904909
Cover, Rear Seat Back Cushion-RH
A68
15914943
Restraint, Rear Seat Headrest (2 required)
A68
15909167
Panel Assembly (2 required)
AZ3, A95
Crew Cab Pickup
Part Number
Description
RPOs
15909157
A95, AZ3
15913991
A68
15913989
Armrest, Rear Seat
A68
20833414
A95, AZ3
20833416
A95, AZ3
20833415
A95, AZ3
20833363
A68
20833364
A68
20833365
A68
20833366
A68
20904119
Armrest, Front Seat
AZ3
20904111
AZ3
15909167
AZ3, A95
UUV (Avalanche)
Part Number
Description
RPOs
15909157
A95, AZ3
20904869
AT5
20904866
Armrest, Rear Seat
AT5
20833414
A95, AZ3, AE7
20833416
A95, AZ3, AE7
20833415
A95, AZ3, AE7
20904119
Armrest, Front Seat
AZ3
20904111
AZ3
15909171
Armrest, Front Seat
AE7
15909181
Cover, Passenger Seat Cushion Center Front
AE7
20904881
AT5
20904878
AT5
20904875
AT5
20904872
AT5
15909167
AZ3, A95, AE7
Utility
Part Number
Description
RPOs
15909157
AE7, A95, AZ3
15913991
AS3, AW2
[Except SEO Seat (5T5) & (AQY)]
20904837
AQY, AS3, AW2
[Except SEO Seat (5T5)]
15913989
Armrest, Rear Seat
AM8
20905030
Restraint, Rear Seat #2 Headrest
AM8 Model 107
20905033
AM8 Model 109200
20833414
A95, AZ3, AE7
20833416
A95, AZ3, AE7
20833415
A95, AZ3, AE7
20904119
Armrest, Front Seat
AZ3
20904917
A68
20904111
AZ3
20905042
AM8
20905045
AM8
20905036
AM8
20905039
AM8
19256184
Cover, Rear Seat #2 Back Cushion-LH
AW2
19256186
Cover, Rear Seat #2 Back Cushion-RH
AW2
20904829
AS3
20904828
AS3
19256188
Cover, Rear Seat #2 Cushion-LH
AW2
19256190
Cover, Rear Seat #2 Cushion-RH
AW2
20904823
AS3
20904822
AS3
15909171
Armrest, Front Seat
AE7
15909181
AE7
15909167
AZ3, A95, AE7
Let me add this also....those that have not had the new 2010 style seat covers installed (such as myself) will be in trouble if you ever need a single cover replaced (say the front seat passenger bottom cover due to it getting ripped,damaged,etc.) this is because GM has already started discontinuing the old style seat covers on the '07-'09 trucks,as a matter of fact if I look up seat covers for an '07-'09 truck they only list the 2010 seat cover part numbers,there is a note stating that all other seat covers must be changed due to an appearance difference.
And before you ask....NO,This is NOT covered under warranty if you need to replace a single "old-style" cover,but must buy all "new-style" covers due to the difference (IE-GM will NOT pay to replace the remaining old style covers with the new ones just because you need one new cover)
So Rich. That list of part numbers you posted. Those are the part numbers that can be replaced and covered by the TSB? If those aren't are the part numbers listed somewhere in this HUGE thread? I was always under the impression that I couldn't change my seats because I thought it was only for 07-08;s
Those are the part numbers you would need Brett,They cover '07-'09 model-years.
The 2010's are NOT involved/affected by the TSB,All 2010's have the new fabric/material.
Nothing for nothing but the 2010 seat material is junk, my black seats look grey from the lint. I really wish there was something GM would do to fix it.
  • 4 weeks later...
Glad I found this thread. I'm going to try and get mine replaced on my 08 cc. These ebony seat have been driving me crazy with all the hair and lint. It's my biggest complait so far. The tea cup size diesel tank is my other issue. ?????????????????
Make sure you have a Dealer that has real techs or yours might end up like mine. Check the video in my sig.
They do make great bachelor seats though as another member mentioned because you'll never have to use a lint brush on your clothes. :eek:
I have no idea of they changed material but I have a 2011 xCab ebony cloth and it picks up lint and hair LIKE CRAZY!!! Is this material suposed to be the upgrade or should I start squawking?
You have the new and improved fabric, :eek::lol: It took GM 4 years to come up with this crap. They will never come up with a nice fabric till the new model because if they actually release an acceptable fabric that does not atract lint, everyone will want their crap replaced, and that would wreak havoc on profits.
WOW!If what i have is so called "improved" I cringe the thought of what you guys suffered with before. It looks great when its clean but ayayayyy is it ever clingy.
Mine just came in, you guys are making it sound like its not worth the trouble. Is it? Im thinking yes, just for the fact that if i do need one replaced i dont have to do them all.
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
