New Tool Box
Here is the new tool box that I got last night hope you like it ; ) and the best part is that it was FREE...
Free as in "found it along side of the road", or someone else bought and paid for it and gave it to you as a gift? :lol:
LOL I wish it was one of those found on the side of the road deals nope it was a gift..
Nice! Been looking for one, that is exactly what i want :lol:
Its a Husky and I have seen them at Pep Boys..
How does it attach to the bed?
I used 4 self taping 2” screws with a rubber gasket right in to the bed.
you wouldnt have a part number for that (i have been considering getting one of those but I did not like having an over the rail tool box)
Nice! Been looking for one, that is exactly what i want :thumbs:
Thanks for the info. I would also be interested in a part number
Looks like you can just set it down in the bed without using screws if you have a bedrug and a hard folding cover. :thumbs: I could use one of these too, so I can get all the gear off my rear seat.
Looks nice Matt. I can't tell from the pics, but does it seem difficult to get back out? I'd be interested in it if there was enough room on the sides to get your hands in there to pop it out.
I've got one like it, except the top is right at the bed rails. Its pretty easy to get out as long as its empty. I went ahead and used self tapping screws so my extreme acceleration wouldn't throw it into the tailgate...yeah. But mine has handles on the sides that make it pretty easy to get it out (and lets me tie down stuff thats not too heavy).
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
