Antenna Delete Mod
  • 4 months later...
  • Replies 56
looking at some plastic repair/building material to fill the hole, sand and retrxture the material and it cant be
  • Polyethylene (PE)
  • Polypropylene (PP)
  • Thermo Plastic Olefin (TPO)
  • Thermo Elastic Olefin (TEO)
Any thoughts
  • 3 months later...
so does this mean I can just unscrew my antenna and call it good? why are people putting these horizontally in their engine bays?
To maintain FM reception. AM is gonna be hosed though because it requires a vertical antenna.
  • 3 years later...
i know this is an old thread, not sure if anyone has figured out what to do for best appearance on the plastic cap but heres what i did
  • 2 months later...
That looks good. Where did you get the plug?
laying around in the toolbox somewhere. but im sure i got it from napa
like chupe442 said pretty much any automotive store would have these
the shorter the lenght is the better. but you can always trim the length too.
any longer than 1/4 inch and it hits the antenna mount stud (it is siliconed on the backside to hold it in anyways)
  • 4 months later...
You can have a vertical antenna if you just drop the antenna straight down next to its three cornered attachment. a short piece of hardware store hole strap cut to fit will hold antenna upside down quite nicely; same hardware as in original post, just not with wire and connectors.
  • 2 months later...
