Radiator Replacement
cao88c
Hey folks,
I'm new to this site, and I'm glad I stumbled across it. Been reading lots of good stuff.
I have a 1999 Suburban C1500 with a 5.7 (350) engine. Well, the radiator has developed a leak so I went ahead and ordered a new one today hopefully it will be here by Friday so that I can have something to do this weekend! Anyways, I was looking at the old radiator (still in vehicle) and I'm noticing that I have 4 metal hoses (2 on each side of the tanks). I did some research online and found that the two on the driver's side are oil cooler lines, and the two on the passenger side are tranny cooler lines.
The questions that I have are:
When I disconnect these lines, is oil going to spew out of them? If so, what can I use to stop it?
Also, does anyone have some sort of a writeup on changing a radiator on a suburban? Or any tips/ tricks?
I do a lot of work on Jeeps, (mainly axles) so I do have a lot of tools and mechanical know how, but being that this is the wife's vehicle, I want to make sure that everything is right. And I really don't work with auto trannys therefore I don't like messing around with anything that has to do with transmission.
Any and all help is appreciated,
THanks
Probably some small amount of oil and tranny fluid will leak out, but of course it won't be under pressure. Nothing a couple of shop rags can't handle.
I haven't removed a radiator from a suburban, but other than opening the drain cock and emptying the coolant from the radiator, I can't think of anything that you wouldn't notice in disconnecting the shroud, fittings and hoses that would not be obvious.
When you get your new radiator, check the type and position of fluid connections before you start the exchange. It's the best time to discover a problem there. :rolleyes:
nothing crazy about changing a rad Chris,roll the the retaining clips off the fitting as not to disfigure them and roll them back on before putting the lines back in,that is the only thing I've seen some people do incorrectly,lines and coolers dribble abit but blast off the rad mount with either shampoo or what ever,no probs,funny my wife never drove our ol' 'burb,lord rest her soul,see I tore her heart out to put in other lady ,god help me,lol,new girl runs good though,her memory lives on ,sniffle ,I'll stop now,I'm here all week,try the veal!
THanks guys, gmtech4, what retaining clips and fitting are you talking about? Also, I havent had time to look at it (when I get home, it dark out). How does the bottom of the radiator mount? Does it bolt on, or does it sit in a cradle?
Thanks again
the cooler lines should be clipped in the fittings,take the plastic cover off then you can see the clips I was talking about,rad sits in rubber mounts
if you can remove the plastic cap,look for the clip in a groove ,the fitting screws into the cooler yes,do not take them out ,look close with a light .
Ok, once again, got home late and it was dark out. I have to pry out the plastic where the oil cooler and tranny cooler lines go connected into the radiator?
I received the new radiator today, and it comes with 4 brass fittings and o-rings similar to the fittings used on the oil and tranny cooler lines. I thought that those would just un-screw.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,199 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
