Bluetooth Options For 2008 Silverado
  • Replies 735
I found a VCIM inside a wrecked 2009 Vibe.....part number is 96964229......can anyone tell me if this will work for Bluetooth?
I don't think so.
I don't think so.
He only wants $50....I thought is was too good to be true!!!
How about part # 25826499? Supposedly it crosses, but I want to be sure before I buy. It's in a wrecked avalanche.
Also, it was said that there are 2 different switches, one for alum. wheels and one for other? Which part # goes with which switch?
Any info would be great.
Thanks,
JC
Thanks,
JC
Part # 25826499 comes out of 2007-2008 models; therefore, this part does not include bluetooth. I don't understand your second question.
It turns out there is only the 1 switch and it fits all 3 different styles of steering wheels according to my dealer. I ended up with a VCIM out of an 09 Denali, which matches the right part #.
JC
Thanks,
JC
Questions:
I read through all of the posts but did not see a definitive answer as to whether there is a VCIM module that would work in a 2006 2500 HD. I understand that there is a difference in the harness. I currently have a Parrot. The incoming is clear, but my wife says that I sound like I am in a tunnel. I would like to improve the outgoing sound quality. Is there a VCIM that will work for an 2006?
Can someone who has the Bluestar can they tell me if the steeering wheel controls work?
Questions:
Find out if the VCIM module part number that is in your truck now is the same as a 2006 trailblazer if it is then I can't see why it would not work as I just did this swap for an 2009 trailblazer VCIM with bluetooth in my 2006 trailblazer and the only other thing I had to buy was the bluetooth antenna other than that it plugged in and started working right away.
I followed the instructions, I purchased (from a salvage yard) a VCIM out of a 09 Denali, which came with the bluetooth antenna for $115 shipped. I installed it and it worked EXACTLY as described, and perfectly, immediately. I have no red light from onstar, either.
Thanks for the info on this fantastic mod!
Joe Clark
Has anyone noticed that when using the bluetooth theres a lag between hitting the answer button and the call connecting? Because I have! When
Has anyone noticed that when using the bluetooth theres a lag between hitting the answer button and the call connecting? Because I have! When you
Has anyone noticed that when using the bluetooth theres a lag between hitting the answer button and the call connecting? Because I have! When I use the onstar minutes it works like lightning but the bluetooth is just slower maybe its the phone or maybe it just takes time to stream.
JTS
Yeah, I have noticed the same. I also seen that during a call, the radio and air will come back on for a brief second, then go back off, like it lost the connection to the phone. Could be my phone as well. I have a ATT 8525.
